Home > Maintenance & Mods (L322) > 4.4 TDV8 Oil Leak Fix
Page 11 of 38 <123 ... 101112 ... 363738>
Baltic Blue
Sorry to hear you have got problems.
I would print out this entire topic and take it with you to the dealers.
Are you still within the 2 year LR Approved Warranty period?. If so it might be a blessing in disguise to get it sorted under warranty.
Mine run out last June and I fear it is only a matter of time until I suffer a similar failure.
Post #467535 6th Feb 2018 12:08pm
still under warranty Mike but i cant get it booked with a loan car till the end of march.
i think my next move is to positively identify the leak and if it is the oil feed pipe i'll have a go myself [with help from son probably]
so can anyone tell the best place to get a couple of oil seals [bs611?] rather a batch of ten from ebay.. ... - .- -.
Post #467545 6th Feb 2018 1:54pm
Baltic Blue
Stan,
I am in Tenerife on holiday until the end of Feb., but if you can’t get any before I return, then let me know and I will gladly stick you a couple in the post.
Cheers
Post #467548 6th Feb 2018 2:07pm
thats very kind of you Mike... Wink
[is it warm there ?] ... - .- -.
Post #467551 6th Feb 2018 2:10pm
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
tool to help
Hi, Stan
If you do decide to get your son to help, it would good to get hold of these or something like with a magnet inside.
https://www.screwfix.com/p/erbauer-impact-...-set/3477d
It is a must to keep hold of the bolt?
Post #467552 6th Feb 2018 2:11pm
thanks for that but i'm pretty sure he's got that kind of stuff.... Thumbs Up ... - .- -.
Post #467553 6th Feb 2018 2:15pm
Baltic Blue
Stan,
I have been here for a week now and temp each day 20-21c with no rain at all, but yesterday was a bit cloudy and a cool breeze coming in off the sea whilst we were walking the coastal path in the morning.
Post #467554 6th Feb 2018 2:15pm
GAC23
United Kingdom 2015 Range Rover Vogue SE SDV8 Indus Silver
If you get it taken in to the dealer by LR Assist, you'll get a loan car from LR Assist not the dealer - well I did anyway. What do I put here then?
Post #467555 6th Feb 2018 2:21pm
Baltic Blue
Stan,
With the bonnet lid vertical in the service position and the air box removed ( 2x 13mm nuts) it is fairly easy to see the pipe with a mirror and torch. I have checked mine 3 times, but thankfully dry each time.
Cheers
Post #467556 6th Feb 2018 2:23pm
thats what the LR chap did Mike but he didnt use any mirrors to see properly and i didnt want to 'infringe' on his inspection..
i'll get some oil seal rings first just in case i can get my zimmer frame up onto the engine bay to have a look.. Shocked Mr. Green
lovely weather your having there.. Thumbs Up
@G, LR assist chap said the westie was drivable so it was up to me to get it into the dealer hence the long wait for a loan car..sounds like you were lucky with your one.. ... - .- -.
Post #467561 6th Feb 2018 2:34pm
GAC23
I must have been, Stan.
Hope you get yours sorted asap.
Is a loan car essential for you? If not, I'm sure your local stealer will be able to fit you in earlier. What do I put here then?
Post #467562 6th Feb 2018 2:49pm
he can G (2 weeks) , but a few days work will probably turn into a week or more and i don't want to risk that... ... - .- -.
Post #467565 6th Feb 2018 3:05pm
Baltic Blue
northernmonkeyjones wrote:
Well my little bag of prints has arrived, for when it starts leaking. For a few quids it was worth putting them in the tool box for future use!!
Tell him red ones don’t leak and he might send you a couple Rolling with laughter Rolling with laughter
Post #467567 6th Feb 2018 3:07pm
GAC23
That's Main Stealer service for you ... What do I put here then?
Post #467568 6th Feb 2018 3:25pm
nino_nino
I'am willing to bet a pound -main dealer calls a crack in the oil cooler, and +/- 1000 big ones. if they do, ask them to save your old cooler.
if you decide to do it yourself and replace two gaskets and O rings cost is 20 pounds and 3 hour labour and knowledge of job well done. so go for it Stan, you know you can do this. Very Happy Thumbs Up
Post #467571 6th Feb 2018 3:55pm
