Home > Technical (L322) > Delayed Air Con |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7708 |
Ever since I had this one, there seems to be a delay with the cold air coming out the vents from startup..... everything is set correct and working normal, it's fully gassed and works brill, but it can take 5 or so mins for cold to come out. It's like something opens up late....
17th Jul 2017 8:48pm |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3118 |
My guess is your flaps are sticky!!
17th Jul 2017 9:48pm |
Ah.... I shall try that.......
17th Jul 2017 9:52pm |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2385 |
The cause could be the known problem of a sticky refrigerant control valve (RCV) in the a/c compressor.
18th Jul 2017 2:05am |
Sarchopperman Member Since: 11 Aug 2017 Location: Aberdeenshire Posts: 33 |
Do you have access to this TSB? I think my RR refrigerant control valve is sticky and needs replacing RR L322 TDV8 4.4 SE 2019 to present
25th Jun 2018 8:47pm |
I looked on the net but only found foreign links.
25th Jun 2018 9:31pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8486 |
Mine does the same I think.
25th Jun 2018 9:37pm |
Oh I get air....full blast....all hot from outside....forced at you..... then after a while it just goes icy cold and it’s fine...until you turn off, then it’ll either do the same again or be ok.... 2011 Range Rover Vogue SE 4.4 TDV8
25th Jun 2018 10:09pm |
Below is LTB00693V3 which IIRC was sourced from another thread on this forum in which several owners reported their a/c slow to start resolved by replacing the mentioned valve.
27th Jun 2018 7:28am |
kooky_guy Member Since: 25 Nov 2011 Location: Sandhurst, Berkshire Posts: 385 |
Aha. Interesting thread. Mine is doing exactly this, except that sometimes it doesn't ever blow cold, which is a bit annoying in the current weather.
27th Jun 2018 8:07am |
Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545 |
Funnily enough we've just noticed that ours does this.
27th Jun 2018 8:10am |
Weirdly, the faster I drive, the sooner it starts blowing cold... 2010 4.4 TDV8 Vogue SE |
27th Jun 2018 9:13am |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
did somebody replace valve? can it be done with compressor in place? pictures?
27th Jun 2018 9:22am |
Non-English versions of the TSB can be found on the net which show the repair kit part number for the 4.4 TDV8 in the L322 is LR061463 with a repair time of 3.6 hours. This kit and LR061464 appear to cover all LRs affected. The problematic valve also occurs in many other brand vehicles.
27th Jun 2018 11:03am |
