![]() | Home > Maintenance & Mods (L322) > Battery Replacement 2011 TDV8 4.4 |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3819 ![]() ![]() ![]() |
Excellent step by step guide. Thanks 👍👍 G reg 2.5VM Vogue Portofino red 1991- 1999
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 ![]() ![]() ![]() |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
Thanks for pic. scuddriver. have tool, battery and the pictures. ready to go |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7909 ![]() ![]() ![]() |
Cracking write up. Can we add this to the Wiki Stan?
Frans@Yamorna Member Since: 15 Apr 2017 Location: Tzaneen Posts: 147 ![]() ![]() ![]() |
What is this battery disconnect device?Can't one just disconnect the battery starting with the neg.?If this car needs a battery far away from the stealers can you just replace?I have the special 5 point Torx tool to remove the ECU's |
I understand the battery disconnect device automatically disconnects the battery if the car thinks it's been in an accident. It's not a device/tool that you need to buy to disconnect the battery. Does it use a small explosive to fire the connector off the battery in a crash?
From the Workshop Manual....
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2648 ![]() ![]() |
It is not fitted to my MY12. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35642 ![]() ![]() |
great write up, put in the wiki.... |
Thanks Graeme. Good to know. ______________________________
dazza1983 Member Since: 19 Feb 2019 Location: southampton, hampshire Posts: 529 ![]() ![]() ![]() |
Great write up |
I changed my battery back in July last year but did not reset the car even though I have an iid.
Also, I found that I did not need to unplug the multi connector on the control unit, because like Nino I had removed the air box, their was sufficient slack in the harness to simply move it to the side and lift the old battery out.
Thanks Baltic blue. Regards
