Home > Technical (L322) > 4.4 TDV8 MAP sensor |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35326 |
ah, that's where it is ... - .- -.
27th Jun 2017 5:37pm |
Frans@Yamorna Member Since: 15 Apr 2017 Location: Tzaneen Posts: 145 |
Nino,my sensor was totally clogged but after spraying with electronic contact cleaner it looked normal!!
27th Jun 2017 6:35pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3544 |
What does the sensor do exactly?
27th Jun 2017 6:43pm |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
my was block solid and it did not trigger any faults with IIDTool. i will see if i can feel any difference while driving tomorrow. |
27th Jun 2017 8:07pm |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 |
It measures boost to inform the ECU. Here's a good explanation.
27th Jun 2017 8:12pm |
I think it would be quicker to pull out a torx screw driver and do a visual inspection, compared to setting up an IIDTOOL. The IID will give you detailed information. But without knowing the "normal" readings to compare against I don't know how the IID tool would tell you it needs a clean. ______________________________
27th Jun 2017 8:16pm |
it was , i went out and it took me 5 min to pul MAP out,clean it and put it back in.so I will be doing this on a regular basis from now on. maybe every other oil change ( i do oil and filter every 5K km) |
27th Jun 2017 8:36pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2485 |
I cut to size a thin metal plate to fit between the flat flanges where the 2 tubes mate near the throttle body. A better spot would be where the exhaust enters the EGR valve to prevent it sticking but for the test, the very accessible join was ideal. |
27th Jun 2017 8:59pm |
Nino,
28th Jun 2017 5:16am |
this two connectors are fiddly to unplug/remove
28th Jun 2017 6:37am |
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 898 |
When I was doing my oil cooler fix, I had the map sensor out and let the tip of it soak in some brake cleaner.
28th Jun 2017 9:27am |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3772 |
Rar110,
28th Jun 2017 9:53am |
28th Jun 2017 7:35pm |
it is job well wort doing, 150 km later the car is more responsive, smoother and it feels like it has more power. i will be doing this at every oil change. |
30th Jun 2017 1:52pm |
