![]() | Home > Technical (L322) > 4.4 TDV8 MAP sensor |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35630 ![]() ![]() |
ah, that's where it is |
Frans@Yamorna Member Since: 15 Apr 2017 Location: Tzaneen Posts: 147 ![]() ![]() ![]() |
Nino,my sensor was totally clogged but after spraying with electronic contact cleaner it looked normal!!
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3552 ![]() ![]() ![]() |
What does the sensor do exactly?
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
my was block solid and it did not trigger any faults with IIDTool. i will see if i can feel any difference while driving tomorrow. |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 ![]() ![]() ![]() |
It measures boost to inform the ECU. Here's a good explanation.
I think it would be quicker to pull out a torx screw driver and do a visual inspection, compared to setting up an IIDTOOL. The IID will give you detailed information. But without knowing the "normal" readings to compare against I don't know how the IID tool would tell you it needs a clean. ______________________________
it was , i went out and it took me 5 min to pul MAP out,clean it and put it back in.so I will be doing this on a regular basis from now on. maybe every other oil change ( i do oil and filter every 5K km) |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2641 ![]() ![]() |
I cut to size a thin metal plate to fit between the flat flanges where the 2 tubes mate near the throttle body. A better spot would be where the exhaust enters the EGR valve to prevent it sticking but for the test, the very accessible join was ideal. |
Nino,
this two connectors are fiddly to unplug/remove
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 908 ![]() ![]() ![]() |
When I was doing my oil cooler fix, I had the map sensor out and let the tip of it soak in some brake cleaner.
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3817 ![]() ![]() ![]() |
Rar110,
it is job well wort doing, 150 km later the car is more responsive, smoother and it feels like it has more power. i will be doing this at every oil change. |
