Home > Technical (L322) > 4.4 TDV8 MAP sensor
Page 2 of 10 <12345678910>
nino_nino
I tuck my MAP sensor out , and guess what - head of the sensor was solid gray mass, after cleaning the 4 openings appeared.
how was sensor working at all i have no idea.
Post #442883 27th Jun 2017 5:35pm
ah, that's where it is Thumbs Up ... - .- -.
Post #442884 27th Jun 2017 5:37pm
Frans@Yamorna
South Africa 2012 Range Rover Vogue SE TDV8 Zambezi Silver
Nino,my sensor was totally clogged but after spraying with electronic contact cleaner it looked normal!!
Frans 2012 TDV8 Vogue SE 4.4
Post #442886 27th Jun 2017 6:35pm
GGDR
What does the sensor do exactly?
And would you be able to tell it's clogged from say using a IIDTool?
. Cheers, Greg
Post #442888 27th Jun 2017 6:43pm
nino_nino
my was block solid and it did not trigger any faults with IIDTool. i will see if i can feel any difference while driving tomorrow.
Post #442897 27th Jun 2017 8:07pm
rar110
It measures boost to inform the ECU. Here's a good explanation.
http://www.aa1car.com/library/map_sensors.htm ______________________________
Post #442898 27th Jun 2017 8:12pm
rar110
I think it would be quicker to pull out a torx screw driver and do a visual inspection, compared to setting up an IIDTOOL. The IID will give you detailed information. But without knowing the "normal" readings to compare against I don't know how the IID tool would tell you it needs a clean. ______________________________
Post #442899 27th Jun 2017 8:16pm
nino_nino
it was , i went out and it took me 5 min to pul MAP out,clean it and put it back in.so I will be doing this on a regular basis from now on. maybe every other oil change ( i do oil and filter every 5K km)
Post #442902 27th Jun 2017 8:36pm
GraemeS
Frans@Yamorna wrote:
Where did you buy the blank kit for the RR?
I cut to size a thin metal plate to fit between the flat flanges where the 2 tubes mate near the throttle body. A better spot would be where the exhaust enters the EGR valve to prevent it sticking but for the test, the very accessible join was ideal.
Post #442908 27th Jun 2017 8:59pm
Frans@Yamorna
Nino,
How easy/difficult job is it to remove the inlet manifold to clean it?Any things to watch out for?Time it took? 2012 TDV8 Vogue SE 4.4
Post #442916 28th Jun 2017 5:16am
nino_nino
this two connectors are fiddly to unplug/remove
Post #442917 28th Jun 2017 6:37am
mpirie
When I was doing my oil cooler fix, I had the map sensor out and let the tip of it soak in some brake cleaner.
Like Nino says, for all the effort involved, it may be worth removing and cleaning it at regular intervals.
Mike
Post #442925 28th Jun 2017 9:27am
Baltic Blue
Rar110,
Thanks for that explanation link.
It all makes sense now.
Cheers. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #442929 28th Jun 2017 9:53am
rar110
Thumbs Up ______________________________
Post #442982 28th Jun 2017 7:35pm
nino_nino
it is job well wort doing, 150 km later the car is more responsive, smoother and it feels like it has more power. i will be doing this at every oil change.
Post #443138 30th Jun 2017 1:52pm
