Home > Maintenance & Mods (L322) > 4.4 TDV8 Oil Leak Fix
Page 6 of 38 <123 ... 567 ... 363738>
There is some disagreement over what is the correct size and what will work.
The ones I ordered from simply bearings are possibly the correct size, according the GraemeS, as the 9 x 1.8 are an aero size. However I have yet to change them (and have now lost them) as it's not leaking yet....... as the 9x1.8 are a tight fit it would sound right that the 8.73 x 1.78 would be a better fit as the Pipework is likely to be metric and this is the correct size for 9mm spigot into a 12mm hole.
The link is above. Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #425236 28th Jan 2017 3:55pm
Baz1975
Northern Ireland 2015 Range Rover Autobiography SDV8 Firenze Red
Guys, I've done a bit of homework on these, as previous posts, I was unsure of the size & material.
BS611 is a 8.73mm (ID Inside Diameter) x 1.78mm CS (Cross section) 'O' Ring.
Nitrile goes up to 120 degrees C, whereas Viton goes 200 degrees C+.
My local bearing company quoted me £2.50 each, quick search on flee bay, £7.99 for a bag of 10 delivered Northern Ireland!
Not sure if I'm allowed to put on the link, but worth a search for 'BS611 viton O ring'
http://www.ebay.co.uk/itm/222391942006
I will take photos when they arrive & update when fitted.
Hope this is some help to people in future.
Great forum as usual!
Barry Current: 2015 4.4 SDV8 Autobiography
Old: 2011 4.4 TDV8.... OMG
Old: 2003 TD6 HSE Java Black
Work: 2016 VW T6 140
Post #425613 30th Jan 2017 12:59pm
stoutgoose
United Kingdom 2012 Range Rover Westminster 4.4 V8 Zermatt Silver
Warranty
Does anyone know if this repair would be covered by LR Extended Warranty?
Post #426088 3rd Feb 2017 8:23am
proser
Should be as it's a failed part. Regards
Mark
2012 Westminster
GONE - 2007 Java Black FF Vogue, with Ivory interior
Post #426091 3rd Feb 2017 8:54am
mcspreader
United Kingdom 2010 Range Rover Vogue SE TDV8 Zermatt Silver
What mileage can we expect to see this at? I have 69k and no sign.
Post #426162 3rd Feb 2017 7:25pm
Macca314
United Kingdom 2011 Range Rover Vogue TDV8 Fuji White
Hi all my FF as got 93500 miles on the clock, and just starting to leak. Will do this next weekend
This site is simply awesome.
Post #429223 26th Feb 2017 8:24am
Macca314
GraemeS wrote:
A great offer Emirates777 - thanks. However if the o-rings have been upgraded to Viton then they should withstand the heat for a far greater time.
The pipe is the top one in the picture.
Hi all I am just about to do this, I spoke to LR today to get a torque wrench setting for bolt that secures the union HS4
It is torqued up to 10Nm.
Hope this helps
Post #429435 27th Feb 2017 6:04pm
mpirie
I replaced my O rings last night and in the process noticed that there is oil in my coolant, so it looks like I'll have to replace the oil cooler too.
Does anyone know of an effective way of removing the oil from the coolant?
I know it'll need replaced, but how can you tell if all of the oil has been removed and what's the process?
Thanks,
Mike
Post #430441 8th Mar 2017 10:37am
MJdronfield may be best bloke to ask as he had exactly that on his Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #430477 8th Mar 2017 4:41pm
Baltic Blue
What size o rings did you use? G reg 2.5VM Vogue Portofino red 1991- 1999
Post #430490 8th Mar 2017 7:35pm
mpirie
I used those suggested by Barry earlier in the thread: BS611 is a 8.73mm (ID Inside Diameter) x 1.78mm CS (Cross section) 'O' Ring.
Pack of 10 for £8 delivered next day.
They were tight to fit, but after a bit of lube the connector went back in with a satisfying plop Shocked
....it was then i noticed the oil in the coolant Big Cry
I should add that to protect the O rings, i taped up the first groove so the ring slipped over to the second groove.
Post #430494 8th Mar 2017 7:53pm
GraemeS
It's good to know that BS611 fits well - thanks for posting.
Post #430532 9th Mar 2017 1:28am
Baltic Blue
Mpirie, good tip about taping first groove.
My packet of 10 have arrived today, but just checked again and still dry. At least I will be able to replace them when needed.
I was a bit surprised at their size, from looking at the pictures, I was thinking they would be bigger. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #430689 10th Mar 2017 1:43pm
Bought a bag of 10.......
Which I have now lost before doing the fix Big Cry There is nothing that can't be fixed with a hammer😜😜
Post #430745 10th Mar 2017 8:29pm
mpirie
Lol, don't worry, I have 8 spares Rolling with laughter
Just about to start replacing the oil cooler since it''s either the cooler or the gaskets that''s letting oil into my coolant Big Cry
Post #430772 11th Mar 2017 9:17am
