![]() | Home > Technical (L322) > Adaptive Dynamics Fault light |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2575 ![]() ![]() ![]() |
Thanks - just co-incidental with the other problem. |
tomthevet Member Since: 14 Jan 2012 Location: Scotland Posts: 283 ![]() ![]() ![]() |
IanV8 do you recall what fault codes you had?
Jasonreavell Member Since: 13 Mar 2017 Location: Rochester Posts: 1 ![]() ![]() ![]() |
I love google and I love you guys. You've just saved me from a large bill no doubt..
funnyguy1 Member Since: 11 Mar 2010 Location: Sun Valley, Idaho Posts: 387 ![]() ![]() |
I posted a few years ago about the fault and repaired the broken wire but it happened again a few days ago. My dealer
Ticketyboo Too Member Since: 19 Mar 2015 Location: Kilkenny Posts: 38 ![]() ![]() ![]() |
Had the very issue today - coincidentally after doing an emergency stop to avoid running over a dog. Nearside one wire of the pair nicked and broke. This info has saved me a trip to the local Stealer. ![]() ![]() |
bruzer Member Since: 16 Nov 2015 Location: Seattle, WA Posts: 44 ![]() ![]() |
Just got the adaptive dynamics fault light for the 3rd time in as many months. Soldered the broken wire together and electrical taped it the first time; soldered the same broken wire with a bit of an extension wire, heatsinked and electrical taped it the second time... is a crimp connector a good idea to try next or would the plastic melt from the heat? If not, what's recommended I do next to have a more permanent fix? |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2670 ![]() ![]() ![]() |
There is a proper kit from landrover, mentioned earlier in the thread with part nos. |
What's exactly involved in putting in that part yourself? Do I have to un-bound that whole 6 to 10 feet of the bonded cablings that the shock tower wiring is bonded to (which all leads to the connector/harness)? |
kalachnikov Member Since: 03 Jul 2017 Location: Geneva Posts: 13 ![]() ![]() ![]() |
Thank you so much for the hint, same problem and the wire was cut, not even under the screws. Even before. Just put the wire and some tape. Will order the new kit to fix the problem once and for all. |
JWL Member Since: 07 Aug 2016 Location: North Wales Posts: 42 ![]() ![]() |
Thanks for this fix guys - I had this problem a couple of weeks ago - all fixed with 5 mins of soldering and heat shrink and avoided a trip to the dealers |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3551 ![]() ![]() ![]() |
There's a nice youtube on this here:
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35515 ![]() ![]() |
nice find Greg |
Just did mine and all I needed to do was push the grommet back in.
Bryan N Member Since: 01 Jan 2014 Location: Cambridge Posts: 68 ![]() ![]() ![]() |
