Home > General > What Did You Do In Your Full Fat Today
Page 239 of 382 <123 ... 238239240 ... 380381382>
mcspreader
United Kingdom 2010 Range Rover Vogue SE TDV8 Zermatt Silver
I bought it. 2011c Vogue SE 4.4 Oil Burner
1991 Hilux 2.4d MkIII. Sadly goone due to space and time.
2008 Skoda Octavia Scout
2000 TVR Tuscan 4.0
Loads of crap. Gone
Post #426194 4th Feb 2017 12:43am
ajac8
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
Front and rear diff oils, TC oil and fuel filter yesterday. today its air filters, pollen filter and the engine oil change using my new pneumatic pump SWMBO bought me for xmas. Happy days! 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #426227 4th Feb 2017 11:52am
rar110
I fitted spare tyre raising straps. These are pretty much essential to get the spare out of a L322. Very clever way of clearing the spare over the compressor. ______________________________
Post #426397 5th Feb 2017 1:24pm
Weegie
Fitted new rear brake pads. John
GAP iiD BT-Sold
Post #426730 7th Feb 2017 5:19pm
appj62
England 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
Passed MOT with advisory on track rod ends. Gearbox drain and fill (strainer changed). Oil not in bad condition (63000 miles).
All in all pretty chuffed. Previous cars:
S-Max 2007-2013 (only diesel I've had, good car but expensive when diesely bits go wrong, so what's the point?)
Galaxy 2001-2007
Mondeo Estate 1997-2001
Sierra Estate 1993-1997
Uno Turbo 1987 -1993
Fiesta 1984 - 1987
Fiat 127 1982 - 1984
Post #426840 8th Feb 2017 10:04am
Hmb
England 2006 Range Rover Supercharged 4.2 SC V8 Cairns Blue
Had my sc written off after a clown put me through central reservation Friday. 2010 Overfinch 3.6 V8 FFRR gone yee haa
2005 Supercharged 4.2 V8 FFRR (written off)
2007 RRSport v8 3.6
1996 300tdi Disco 1
Post #426977 8th Feb 2017 11:12pm
hamlet
Ireland 2006 Range Rover HSE Td6 Buckingham Blue
Shocked Shocked Shocked That doesn't sound good......
Hope all are ok and you get a satisfactory outcome.
Post #427035 9th Feb 2017 1:07pm
RR2008HSE
^ x2 Shocked
Post #427125 10th Feb 2017 2:36am
TerryG
England 2008 Range Rover Vogue SE TDV8 Java Black
I used mine to pull a VW golf out of a barn, across a farm on "tracks" and 7 miles home. The pressure washer got a serious work out getting both cars back to the colour they left the factory but driving the FF off-road is good fun and off-road towing is effortless.
Post #427406 12th Feb 2017 11:54am
Paul1234002
England 2006 Range Rover Vogue 4.4 V8 Barolo Black
I did nothing but look at it wondering what the Hell is wrong with the suspension............
Post #427407 12th Feb 2017 11:56am
Big Boy R44ROV
Went for a drive in the Dales This was taken on the road between Kilnsey and Malham. Only other car we saw was an L405 on the same road who waved!!
Still amazed me as to how many numpties in rear wheel drive BMw's and Mercs think they can drive roads like that when its covered in ice and snow. I advised 3 such people to turn round ! http://www.fullfatrr.com/gallery/albums/us...Rangey.jpg Tony
You're always in the Censored ........it's just the depth that varies
2014 L494 5.0 S/C AB Silver
2014 L494 3.0 HSE in Chilli
2014 SL63 AMG White
Gone:
2011 5.0 L322 White (Stolen)
07 4.2 SC in silver.
06 4.2 SC in black RSE
RRS 4.2 SC in Black RSE
52 4.4 Vogue in silver
04 Mercedes CLK 320 Conv
03 4.0 V8 ES Disco in Silver
00 TD5 90 County
98 4.6 HSE in Epsom x3
97 3.9ES Disco
93 L 4.2 LSE in black
too many classics to mention !
Post #427561 13th Feb 2017 12:40pm
Dave 67
England 2004 Range Rover Vogue 4.4 V8 Java Black
Drove all the way to MK to get transfer box oil as only dealer I could find with it in stock, oddly they had 10ltrs now only 9 Smile
Got home fitted oil seal to rear wiper shaft so water stays on the outside of the rear window Thumbs Up
Then changed the transfer box oil, so all the oils changed bar the steering, next on the list PCV valve and hoses as they are becoming a soft, then valve cover gaskets, spark plugs and fuel filter.
Will get an indi to change the brake fluid, hope to drop on a set of Brembo callipers if I'm lucky one day. 2004 4.4V8 Vogue
BMW 330CD
BMW523i
Escort Mexico MK1
1974 airportable series 3
Post #427658 13th Feb 2017 11:22pm
Sharpy1980
United Kingdom 2010 Range Rover Vogue TDV8 Stornoway Grey
I replaced the osf abs sensor today which went a lot easier than expected, I had to carefully drill the old sensor out as it broke off when trying to get it out but at least the bolt came undone ok. I then thought I'd quickly replace the header tank as I have had the low coolant warning on for ages but the lowest hose connecter fell apart when removing it, the o ring in it had swollen so it wouldn't go back together, I then spent ages trying to find the right size o ring and get it all back together and the best bit is no more warning on the dash Thumbs Up
Post #428036 16th Feb 2017 10:39pm
b348xyx
United Kingdom 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
Wing Mirrors were looking bit worse for wear, from all the country lanes...
So thought be nice to colour code them to the car, layer of primer to try remove the scratches.
4 layers paint and 2 clear coat.
need to give them a good buff up but there looking pretty good and alot better then before
 2003 Range Rover 4.4 Litre V8 - Adriatic blue
2003 Range Rover 4.4 Litre V8 -Maintenance History Click Here = http://www.fullfatrr.com/forum/topic39687.html
Post #428066 17th Feb 2017 10:14am
Sharpy1980
I've just replaced the switch on the bottom of the ignition due to having intermittent starting problems, getting the centre console out was harder than I thought it'd be but if I had to do it again it would be a doddle as I think I took more out than I needed figuring out where the screws are, wish I took some photos for a how to as I couldn't find one apart from the workshop manual one which isn't that clear.
Post #428334 19th Feb 2017 11:18am
