![]() | Home > General > What Did You Do In Your Full Fat Today |
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1664 ![]() ![]() ![]() |
Front and rear diff oils, TC oil and fuel filter yesterday. today its air filters, pollen filter and the engine oil change using my new pneumatic pump SWMBO bought me for xmas. Happy days! 405 AB exec seats Baltic and Cirrus
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 ![]() ![]() ![]() |
I fitted spare tyre raising straps. These are pretty much essential to get the spare out of a L322. Very clever way of clearing the spare over the compressor. ______________________________
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3255 ![]() ![]() ![]() |
Fitted new rear brake pads. John
appj62 Member Since: 07 Aug 2013 Location: Cheshire Posts: 424 ![]() ![]() ![]() |
Passed MOT with advisory on track rod ends. Gearbox drain and fill (strainer changed). Oil not in bad condition (63000 miles).
Hmb Member Since: 12 Jun 2016 Location: Essex Posts: 90 ![]() ![]() ![]() |
Had my sc written off after a clown put me through central reservation Friday. 2010 Overfinch 3.6 V8 FFRR gone yee haa
hamlet Member Since: 18 Nov 2016 Location: Kildare Posts: 294 ![]() ![]() ![]() |
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 ![]() ![]() ![]() |
^ x2 |
TerryG Member Since: 07 Feb 2017 Location: Midlands Posts: 17 ![]() ![]() ![]() |
I used mine to pull a VW golf out of a barn, across a farm on "tracks" and 7 miles home. The pressure washer got a serious work out getting both cars back to the colour they left the factory but driving the FF off-road is good fun and off-road towing is effortless. |
Paul1234002 Member Since: 06 Oct 2015 Location: Manchester Posts: 32 ![]() ![]() ![]() |
I did nothing but look at it wondering what the Hell is wrong with the suspension............ |
Big Boy R44ROV Member Since: 14 Nov 2011 Location: Chadderton, Oldham Posts: 555 ![]() ![]() |
Went for a drive in the Dales This was taken on the road between Kilnsey and Malham. Only other car we saw was an L405 on the same road who waved!!
Dave 67 Member Since: 11 Dec 2016 Location: Oxfordshire Posts: 34 ![]() ![]() ![]() |
Drove all the way to MK to get transfer box oil as only dealer I could find with it in stock, oddly they had 10ltrs now only 9 |
Sharpy1980 Member Since: 20 Nov 2016 Location: Kent Posts: 55 ![]() ![]() ![]() |
I replaced the osf abs sensor today which went a lot easier than expected, I had to carefully drill the old sensor out as it broke off when trying to get it out but at least the bolt came undone ok. I then thought I'd quickly replace the header tank as I have had the low coolant warning on for ages but the lowest hose connecter fell apart when removing it, the o ring in it had swollen so it wouldn't go back together, I then spent ages trying to find the right size o ring and get it all back together and the best bit is no more warning on the dash |
b348xyx Member Since: 29 Sep 2016 Location: Kent Posts: 319 ![]() ![]() ![]() |
Wing Mirrors were looking bit worse for wear, from all the country lanes...
2003 Range Rover 4.4 Litre V8 -Maintenance History Click Here = http://www.fullfatrr.com/forum/topic39687.html |
I've just replaced the switch on the bottom of the ignition due to having intermittent starting problems, getting the centre console out was harder than I thought it'd be but if I had to do it again it would be a doddle as I think I took more out than I needed figuring out where the screws are, wish I took some photos for a how to as I couldn't find one apart from the workshop manual one which isn't that clear. |
