Home > Technical (L322) > Lower thermostat modification V8 4.4 M62 2002-2005
Page 5 of 12 <123 456 ... 101112>
holidaychicken
That's my understanding, the vemo should fit straight in and give you a running temp of around 93-95 degrees.
I think my head gasket is good, i was worried about the discolouration of the oil but i think that was left over from the flush i did before changing out the timing gear either that or condensation from my very short infrequent runs, i have bled the cooling system much better now by raising the front of the vehicle and done an oil and filter change and it is not using any water, the oil is staying perfectly clear and it is pulling like a train with the new MAF so i am cautiously optimistic that i am ok. i don't have any oil light flicker either when it is hot. Thumbs Up
Bit more info here from the bimmer chaps,
http://forum.roadfly.com/threads/13174777-Lowering-Temps-on-540
http://www.bimmerforums.com/forum/showthre...thermostat
Even more interesting is the possibility of a separate body and thermostat, all be it without the quick connector, but now i am just getting carried away...
http://www.ebay.co.uk/itm/BMW-Thermostat-H...2097001970
Post #424508 24th Jan 2017 12:23am
rvbush
United Kingdom 2011 Range Rover Vogue TDV8 Stornoway Grey
Thinking abpout this hot running issue. My car smells pretty damn hot after a run as others have described. Is it possible it's the thermostat heater that's failed causing it not to 'force' it open fully and thus run closer to 105 deg all of the time when it opens fully by itself? Drives:
2010 FFRR TdV8 Vogue - Stornoway Grey
2010 FFRR TdV8 Vogue SE - Zermatt Silver
1998 BMW E36 M3 GTII
Post #424534 24th Jan 2017 9:35am
holidaychicken
Normal running conditions are with the heater off, only under heavy load will the heater cause the stat to open.
Diagnostics will tell you if the heater is functioning
Post #424793 25th Jan 2017 9:10pm
It's not a hot running issue, they were designed to run at a very high temp, it is a normal feature but not a desirable one, hence this mod.... Thumbs Up Pete
Post #424799 25th Jan 2017 9:30pm
AusRR
Australia 2003 Range Rover HSE 4.4 V8 Zambezi Silver
Guys can I just check this mod doesnt affect your fuel economy noticeably?
Post #425116 27th Jan 2017 9:34pm
Made mine better.... Pete
Post #425136 28th Jan 2017 1:04am
MarkNL
Netherlands 2007 Range Rover Vogue SE TDV8 Java Black
Hi,
So I ordered the BEHR thermostat model TI 3288 for the 740 diesel. It is exactly like in Andy's pics, with the 88 degrees indfication on the side - just where the connector is on "our" BEHR TM 12105 model.
I was hoping to install the connector on the 740D model.... the little circle plate pops out easily on the model BEHR TI 3288 for the 740 diesel, but the connector on "our" 105 degree model is glued in - and impossible to get out without breaking it to pieces.
My indy garage is 100% certain he needs to ADD the temp connector... if not hes is 100% sure of fault code.
UKMarine. / you indicated driving without that connector fitted... no fault code generated at all ?
Hope to hear more.... Mark Offringa
Utrecht Netherlands
2007 L322 / 3.6 TDV8 / Vogue / Java black
2002 Mini Cooper / 1.6 116 hp / Red + white roof / the magic back-up Smile
Gone:
2002 L322 / 4.4 V8 / Vogue/ Adriatic blue
2000 Audi A6 / V8 4.2 / Brilliantschwarz
2003 L322 / TD6 HSE / Adriatic blue
Post #425586 30th Jan 2017 12:19pm
UK Marine
England 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
Hi, it does generate a fault code, just not one sufficient to put a message in the instrument panel.
Hope that helps as I've been driving mine for a good four months like this and it's behaving itself perfectly.
Regards ______________________________
Simon
Range Rover Classic 3.5 efi - Gone
Range Rover Classic 3.9 efi - Gone
Range Rover Classic 4.2 LSE - Sadly gone
Land Rover 110 3.5 - Gone
Range Rover P38a 4.0 SE - Pleased it's gone
Range Rover P38a 2.5 DHSE - Just sold
Range Rover L322 4.4 v8 Petrol - Current
Post #425607 30th Jan 2017 1:37pm
Well he is 100% wrong, it is not a temp sender it sends power to open the stat, what can you connect it to...??????
It does show a soft fault i.e. it says it's not working but it has absolutely no effect on anything else and as it's a soft code it CANNOT put a warning light on....
This is what it will show
0x48C Electric thermostat circuit fault
Thumbs Up Thumbs Up Pete
Post #425609 30th Jan 2017 1:41pm
UK Marine
That's the fault I have and it doesn't effect anything, not even my roverphobia Thumbs Up ______________________________
Simon
Post #425611 30th Jan 2017 1:47pm
MarkNL
Thanks gentlemen,
The diesel version is going in ! Thumbs Up Thumbs Up Mark Offringa
Utrecht Netherlands
Gone:
Post #425621 30th Jan 2017 2:52pm
rvbush
I have literally just finished installing the diesel 88deg thermostat. Not started up yet though as need to pop out to get some coolant. Nobody mentioned what a bit*h that lower l/h bolt is to get at!!
Edit: Now all topped up with coolant and run until thermostat openned, all seems good. Just need to let it cool off to check coolant level and we're off, I hope! Drives:
Post #425631 30th Jan 2017 3:27pm
Long reach 3/8 drive 10mm socket fitted perfectly on mine... be a pig with just a spanner though.... Thumbs Up Pete
Post #425708 31st Jan 2017 1:06am
rvbush
I actually used a 1/4 drive with extension, but I still wouldn't say it was easy!!! Pity anyone with relly big hands trying to do it. Drives:
Post #425726 31st Jan 2017 8:28am
holidaychicken
It is a piece of wee to fit on the Petrol M62 engine and I also used a1/4 drive ratchet and bar😁
No dash warning for me either
Post #425776 31st Jan 2017 7:41pm
