![]() | Home > Technical (L322) > Lower thermostat modification V8 4.4 M62 2002-2005 |
doclees Member Since: 25 Jun 2015 Location: PA Posts: 672 ![]() ![]() ![]() |
For a complete answer you need an LPG guy but engine temp still hits the 200 F mark so I see no reason why not. |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1560 ![]() ![]() |
I can't see why it should. The cars will run quite happily without the thermostat heating element. Ron B. VK2OTC 2003 L322 V8 Auto 2007 Yamaha XJR1300 Previous: 1983, 1986 RRC; 1995, 1996 P38A; 1995 Disco1; 1984 V8 County 110; Series IIA |
tb10 Member Since: 17 Feb 2015 Location: Bromsgrove Posts: 341 ![]() ![]() ![]() |
The LPG switchover will depend on a number of defaults (time, revs falling, pressure etc) and two defaults relating to the temperature will be the temperature switch over value (obviously) but also the time to switch to LPG from 1. Cold and 2. Warm / hot
Jmckenzie295 Member Since: 18 Apr 2018 Location: Glasgow Posts: 17 ![]() ![]() ![]() |
Thanks guys, very helpful.
So I done the modded thermostat today, all fits together nicely with the housing etc. However, only 3 bolts go in, the 3Rd will not seems to be the bottom two are slightly out.
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
You shouldn’t need to separate the parts and if the bolts go through with it out then you should be fine when fitted. Did you try rotating it 90 degrees in the housing and did you grind off the old mounts ok ? |
Everything is grinded and smooth, the holes don't line up at all if at any other variant. Only one way. I would agree, but if when all bolts are in and the last hole ends up at a slight angle it won't go into the engine side of the thermostat. Well that's the only explanation I can come up with. |
I know one of the bolts is difficult to access which is why they supply cap heads but I used all all hex head as I used a 1/4 drive ratchet. Did you use the cap heads supplied and can you get all four bolts in lose to start them and then tighten ? |
The last one finally caught the thread. Alot of shifting about. But got their in the end.
nosmo Member Since: 05 Nov 2017 Location: Derbyshire Posts: 41 ![]() ![]() |
Is this mod still available? |
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 833 ![]() ![]() ![]() |
Certainly is, here’s the link
Thank you |
Frankly, having done the mod, I wouldn't bother. I'd buy the bolt-on non-heated thermostat housing that has a lower temp thermostat.
