![]() | Home > Technical (L322) > Lower thermostat modification V8 4.4 M62 2002-2005 |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
That's my understanding, the vemo should fit straight in and give you a running temp of around 93-95 degrees.
Normal running conditions are with the heater off, only under heavy load will the heater cause the stat to open.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8557 ![]() ![]() ![]() |
It's not a hot running issue, they were designed to run at a very high temp, it is a normal feature but not a desirable one, hence this mod.... ![]() __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand Sold 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Sold 2002 L322 Vogue 4.4 V8 Epson Green (Fatty Offroader) Sold -Click for Project Fatty off roader- |
AusRR Member Since: 27 Jan 2017 Location: Sydney Posts: 7 ![]() ![]() ![]() |
Guys can I just check this mod doesnt affect your fuel economy noticeably? |
Made mine better.... Pete
MarkNL Member Since: 26 Jan 2014 Location: utrecht Posts: 44 ![]() ![]() ![]() |
Hi,
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 833 ![]() ![]() ![]() |
Hi, it does generate a fault code, just not one sufficient to put a message in the instrument panel.
Well he is 100% wrong, it is not a temp sender it sends power to open the stat, what can you connect it to...??????
That's the fault I have and it doesn't effect anything, not even my roverphobia |
Thanks gentlemen,
rvbush Member Since: 08 Jan 2016 Location: Leamington Spa Posts: 545 ![]() ![]() ![]() |
I have literally just finished installing the diesel 88deg thermostat. Not started up yet though as need to pop out to get some coolant. Nobody mentioned what a bit*h that lower l/h bolt is to get at!!
Long reach 3/8 drive 10mm socket fitted perfectly on mine... be a pig with just a spanner though.... |
I actually used a 1/4 drive with extension, but I still wouldn't say it was easy!!! Pity anyone with relly big hands trying to do it. Drives: 2010 FFRR TdV8 Vogue - Stornoway Grey 2010 FFRR TdV8 Vogue SE - Zermatt Silver 1998 BMW E36 M3 GTII |
It is a piece of wee to fit on the Petrol M62 engine and I also used a1/4 drive ratchet and bar😁
