Home > Off Topic - Other Cars > Diesel conversion for a Classic, which engine? |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8293 |
Fair comment... just a thought...
7th Oct 2016 9:53am |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
I will admit to looking at both D1/2's and Diesel Classic RR's and while they are a very useable as an every day car.. the 111 bhp - 123 bhp depending on which engine they have, isn't enough power for what I do... the Merc at 167bhp is border line underpowered and the ffrr at 177 isn't much better
7th Oct 2016 10:15am |
I'll saynit again, you need an F250 or Dodge Ram with LPG install if it's not a diesel
7th Oct 2016 12:15pm |
If you want a Disco1/2 and find or build one from a rot free tub and chassis then really for towing your limited to shoving in a 4bt/6bt with fuelling mods and turbo windup. There is a way to run a twin turbo setup on them for quicker pickup.
7th Oct 2016 2:23pm |
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2575 |
The Cummins are very heavy - OM606 if you're set on something old. Correct answer is probably a modern US diesel pick-up to pull a genuine 3 1/2 tons all day though. |
7th Oct 2016 3:00pm |
Right there are good and bad reasons for this post, I'll try and address them so you've a better idea.....
7th Oct 2016 11:45pm |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2033 |
Your quest might be so difficult, that it may just be easier to take a career change!
8th Oct 2016 8:30pm |
I'm not brave enough to tow with the ffrr... I have every confidence that it will end in tears
8th Oct 2016 10:14pm |
Have you considered a 4.2 SC on LPG ?? Plenty torque/BHP and a pretty strong gearbox (apart from the one solenoid issue and the coolers on the early models). If you get a later one 2007/2008/2009 the cooler issues should be solve (better coolers) and these models are not very expensive anymore and pretty bullet proof. MY 2010 5.0 SC Galway green and sand interior!!
8th Oct 2016 11:43pm |
I did look but they are TDV8 money.... so why not stick with a tractor to do a tractors job
8th Oct 2016 11:55pm |
8th Oct 2016 11:56pm |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1536 |
ex-Australian Army Land Rover 6x6 Perentie. No rust, low km (I know a bloke who bought one with only 800 km on the clock), unburstable Isuzu 3.9 litre 4BD1-T Turbo. Also they have a wider body than a standard LR.
8th Oct 2016 11:58pm |
Just a couple of problems there bud, if I'd wanted Land Rover I think I should be able to find one in the UK But I find them too cramped to drive any distance...
9th Oct 2016 1:22am |
Miggit, forget about BHP, it's torque that does towing. When I drove wagons for a living I had many tug units, but chief among them was a Foden. Only 380 horsepower which isn't a lot for 38 tonnes - that's 10bhp per tonne by which reckoning you'd need less than 55 bhp.
9th Oct 2016 7:34am |
