Home > Off Topic - Other Cars > Diesel conversion for a Classic, which engine?
Page 8 of 8 <12345678
sako243
Have you had a hunt through LR4x4? Not wishing to direct people away from this forum but for Land Rover "based" stuff the guys on there are the ones that seem to push the limits a bit more than others.
Seen a few threads on the OM606 into mainly Defenders but a RRC isn't much different to a Defender in that respect. Unfortunately I should head off to work so can't do some more digging for you. Ed
Post #408735 11th Oct 2016 7:24am
miggit
Ed Buddy, I've already discovered that one! I just wish that I could find a definitive build list as there are pages and pages and pages of info Shocked Yesterday I couldn't spell Engineer... Today I are one!
Post #408743 11th Oct 2016 8:57am
Ha e you asked fabrication 4x4 for a quote maybe?
They do some very radical stuff into things so an om606 or bt4 would be a doddle for them and they would be able to advise on stronger boxes for it as well Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #408903 11th Oct 2016 10:50pm
miggit
Shocked Quote Shocked
I'll be doing a Pete on this one buddy! Just getting the game plan and shopping list in order.....
Have already decided to stick with Mercedes 6 speed box and mate it to an LT230, the Land Rover boxes don't appear to be up to the torque produced by a standard OM606 let alone a tuned one Rolling Eyes
Whistle If I can find a suffix 'c' LT230 box then there is still an option to fit the overdrive as well Razz That'll let me play around with the diff ratios and create a monster that will climb up a cliff in high range and still return a good MPG Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #408909 11th Oct 2016 11:18pm
sako243
There was a thread recently with someone who had a TDV6 in a Defender... Ed
Post #408913 11th Oct 2016 11:38pm
miggit
That's OK if you don't mind faffing about with computers and all the pain they can cause....
Whistle Since I have discovered that the Mercedes OM606 tips the scales at 220KG, so that's 10 KG more than a TD6 and 80KG than a rr V8, it can produce up to 500hp and 700Nm of torque, and not an ECU within miles of it Bow down Very Happy The only cables you need are the throttle cable and a stop cable (optional) Mr. Green Yesterday I couldn't spell Engineer... Today I are one!
Post #408917 11th Oct 2016 11:59pm
You still going for some cruise control with it as well?
Maybe retrofit AC as well while you have the access as we know that's deffo something you want to help keep the inside of the thing dry Wink FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #408924 12th Oct 2016 4:46am
You could also take another route....
https://www.facebook.com/groups/3908966109...5778755375 FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #408926 12th Oct 2016 5:10am
miggit
I hadn't given cruise control much thought Shocked but now that you have... it would be nice.. but I'd then be back into ECU Shocked Shocked And I'm really trying to divorce myself from them Whistle Might be able to fit one of those simple ones that you used to be able to get as an after thought.....
But to be honest, as much as I love cruise, I don't really use it much when towing, as I normally chugging along A roads not motorways. And due to the super stable nature of mobile toilets Rolling with laughter Rolling with laughter (they are all over the place cos of the Censored ) I have to use the throttle because of constantly having to adjust to stay in a straight line Shocked
A/C hadn't given that any thought either Rolling Eyes I suppose I could use this to control the environment.....
A boot full of them should do the trick Rolling with laughter Rolling with laughter
But now you have brought the chilling subject to light Shocked Big Cry Big Cry Big Cry WANT A/C, NEED A/C.... Feel another retro fit coming on..... The bit inside the Classic is easy to fit, been there and got the t shirt.... But that was an piston pump system running R12...
The OM606 has A/C but that will be a rotary affair, and more than likely run R134a.... wonder what will happen.. Rolling Eyes Yesterday I couldn't spell Engineer... Today I are one!
Post #408927 12th Oct 2016 5:43am
They won't cool it though lol FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #408936 12th Oct 2016 8:03am
chex
Kenya
If you do it please document the process. 2004 L322 V8
Post #408942 12th Oct 2016 8:14am
miggit
Thumbs Up No Worries Matey Wink Yesterday I couldn't spell Engineer... Today I are one!
Post #408952 12th Oct 2016 9:13am
