Home > Off Topic - Other Cars > Diesel conversion for a Classic, which engine? |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
Your completely right about the torque..... but it's not just the torque alone, it's where the torque is delivered.... high low end torque is what's needed There are a lot of petrol engines with really impressive torque figures, until you see where they come in at.. 4000 rpm +... no good for towing, need max torque below 2000 rpm to be any good And while I do realise that Torque and Horse Power don't necessary go hand in hand, I have yet to come across a high power engine that didn't have a reasonable torque curve...
9th Oct 2016 9:49am |
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2567 |
BT6 weighs over half a tonne, an OM606 is far more sensible approach. |
9th Oct 2016 12:15pm |
Agreed. That was the engine which took Otto to almost every country in the world.
9th Oct 2016 1:20pm |
Now it's funny that you should talk about D3 manuals eating clutches.. that was the experience that a bog company I knew found out...
9th Oct 2016 11:13pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8536 |
I tow our digger on a flatbed which is 3.5 tonnes all up, and it's the same with the D4. Start in low range if you have a slight slope it's what the manual says too.
10th Oct 2016 6:25am |
also dont forget what ever you get you will have to have a tacho fitted to the tow car. There is nothing that can't be fixed with a hammer😜😜
10th Oct 2016 6:33am |
How the are you doing the low to high in a ffrr, mine wont select gear without the brakes being on Yesterday I couldn't spell Engineer... Today I are one!
10th Oct 2016 7:18am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16294 |
You only need your brakes on under 10ish MPH
10th Oct 2016 7:27am |
Low range - get the car rolling. Into neutral, change low to high, back in D and away you go. They all do it AFAIK |
10th Oct 2016 7:28am |
Im also in favour of a D3/4 manual... Great tow cars and NO crappy auto box to constantly worry you
10th Oct 2016 7:31am |
Well I've been doing a bit of digging on the wonder web with regards to fitting a Mercedes OM606 engine in to a Classic, and giving it a little boost The engine can be boosted up to around 450 - 500 Nm @ 2000 Rpm for under a grand.... not an ecu with in a mile of it
10th Oct 2016 8:11am |
yep just like that in the FF, get rolling in Low, knock it into neutral, then into high, then back into D.
10th Oct 2016 4:27pm |
chex Member Since: 17 Sep 2012 Location: E. Africa Posts: 130 |
Do you know who does the conversions? 2004 L322 V8 |
10th Oct 2016 6:28pm |
chex, I have no idea who does these conversions , but if you go back to page 3 of this thread and scroll down to DeRanged Rover's post there is a "pm" button at the bottom of his post... you'll be able to ask him direct
10th Oct 2016 10:57pm |
