![]() | Home > Off Topic - Other Cars > Diesel conversion for a Classic, which engine? |
lighthouse Member Since: 22 Feb 2016 Location: Great Notley Posts: 513 ![]() ![]() ![]() |
Nice loo's much better than the festivals I goto. |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16341 ![]() ![]() ![]() |
There’s an answer in there somewhere Lighthouse |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
Not hear say, but straight from the horses mouth, it was the gearbox builder himself..... as I said I don't know if it applies to the Range Rover or another car with the 8 speed gearbox..... it's not like Range Rover are the only people to fit that 8 speed box in their car there must be 100's of different motors out there.... It isn't inconceivable that some bright spark has over done the torque and created a TD6 scenario |
That's not a bad idea... but I thing that if I'm going to take the plunge then I'll stick to a diesel, as they will give more pulling power per litre than a petrol engine, and I really want to get back to basics and not have any ECU's |
Crazy option but I know of someone who could build a WJ jeep with a 6bt engine in it and this no ecu's and towcap of 3.5tons. Nissan patrol axles or standard jeep units with air or lunchbox locker in for grip in wet bits and a fuel pump strong enough to take very nasty stuff for fuel so reduced fuel costs even more.
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 ![]() ![]() ![]() |
Hmm. RRC engines. I first thought of the 300 tdi, but you'd already considered that.
True but then just avoid wet mucky stuff 😂😂😂 There are some nice F350's about though, one with the triton V10 and massive LPG tank setup! FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's Mantec Sump Guard, Rigid Load liner, MY10 BT upgrade. ![]() |
You insure on the vin number, a good few companies do it.
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
with what you are trying to do, Miggit....it might be easier to get a different job! |
FYI before they start the rebuild did you see what I put on your gearbox thread? 😉 FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
jonnyboy54321 Member Since: 29 Jan 2016 Location: surrey Posts: 380 ![]() ![]() |
I agree about the D2 td5, had 3, a much better drive than a d1, but the auto not the best gearbox for towing I found.
D2 rear springs is an easy conversion... but I'm back in the ECU territory again |
