Home > In Car Electronics (L322) > 2002-2006 Replacement head unit running Android |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8363 |
Yes it can and it SHOULD be even easier as it should all plug in at the front... but take that with a pinch of salt... it would definitely fit though..... Pete
29th Aug 2015 8:41pm |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 |
sounds an excellent idea. |
2nd Sep 2015 6:22pm |
pietertje Member Since: 30 Nov 2014 Location: Rotterdam Posts: 152 |
Sounds great!
2nd Sep 2015 7:57pm |
Top job Kevin, I've asked several folk as guessed it can't be that hard but not had any luck... would be excellent if you could sort it out... Pete
2nd Sep 2015 8:02pm |
marcevs72 Member Since: 07 Sep 2015 Location: devon Posts: 16 |
Just used the guide today to fit an iPhone stereo and made a daunting job so easy.great write up and many thanks mate for taking the time to help others out 👍 |
13th Sep 2015 5:15pm |
williamb76 Member Since: 12 Jan 2014 Location: Surrey Posts: 6 |
Evening all,
14th Sep 2015 8:12pm |
DT277 Member Since: 02 Sep 2015 Location: South East Posts: 12 |
I too am looking for someone to install a new android head unit in much the same way Haylands/Pete did.
16th Sep 2015 1:45pm |
jetset Member Since: 24 Sep 2015 Location: Bedford Posts: 10 |
Great reading, many thanks to all.
24th Sep 2015 5:33pm |
MrKev Member Since: 09 Aug 2015 Location: UK Posts: 22 |
I've got the amp staying on all the time (when needed) by sending the keep alive message to it. At the moment it defaults to 'quiet' on startup and I need to send a bunch of volume up messages too, I haven't decided on the optimum number yet, butbive been sidetracked the last couple of weeks.
24th Sep 2015 7:04pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7850 |
I believe the bm54 starts in a different mode depending on whether it sees the dsp on the ibus. It may be that causing an issue. Don't know for sure though. I think they talk to each other......
24th Sep 2015 7:10pm |
Had two leads from Erisin now that have had problems inside the filter box on the long lead, the little black box on the power lead, they had been over soldered and burnt the PCB track off... both gave intermittent faults... managed to repair them with some more soldering, moved the wires to different points on the PCB...
24th Sep 2015 9:13pm |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 798 |
I have just received a unit from AliExpress, Shipped from Singapore Took 5 days to arrive US$333 Via DHL.
25th Sep 2015 3:37am |
Time for a progress update...
27th Sep 2015 3:59pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
Kev, buddy you lost me at Hello But that looks impressive I knew that it wouldn't be long before someone with knowledge got involved I can't wait to see, sorry hear the end result
27th Sep 2015 4:20pm |
