![]() | Home > Technical (L322) > Adaptive Dynamics Fault light |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6373 ![]() ![]() ![]() |
My Dad's RR had this (MY10 TDV8 VSE) and so I went round to check if the wires were the cause of the Adaptive Dynamics fault.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35629 ![]() ![]() |
will wiki it |
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 ![]() ![]() ![]() |
Your Dad's car looks as though it spends a bit of its time off road!! |
Has anyone fitted the approved mod? Its about 40 quid from memory and I wonder if its worth it?? |
What exactly is the approved mod? Is it worth it if the fix is so simple? Probably cost me 10p in bits. Discovery 4 HSE
XXXAngelXXX Member Since: 25 Mar 2007 Location: Stuttgart Posts: 4995 ![]() ![]() ![]() |
approved mod part = LR032839 wiring 2 of them cost 80,54 Euros + Vat here + another 150 Euros + Vat to do the job !!! |
this is the part
Y. O. L. O. . |
Just an extension by the looks of it. Discovery 4 HSE
Stan that is the same price - you need 2 of them |
Looks like the same grade wire but in a shrink wrap sleeve to make it tougher. Discovery 4 HSE
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8749 ![]() ![]() ![]() |
More like a rubber flex (like you would get on a power tool) than wires with heat shrink. There is nothing that can't be fixed with a hammer😜😜
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2681 ![]() ![]() ![]() |
Mine has just bonged with this message, hopefully easy fix as noted! can anyone who has soldered comment if they have had further issues or is it best for the upgraded part as listed by Stan?
silversurfer Member Since: 24 Oct 2013 Location: londinium Posts: 84 ![]() ![]() ![]() |
Having soldered both sides and then only to have a second additional break occur I bit the bullet and ordered two new replacement kits Just as well because the wire insulation was badly cracked in several places, and the fault reappeared again a few days later.
Perfect, ordered from Dan |
