Home > Technical (L322) > Adaptive Dynamics Fault light
Page 4 of 10 <12345678910>
My Dad's RR had this (MY10 TDV8 VSE) and so I went round to check if the wires were the cause of the Adaptive Dynamics fault.
Lo and behold, straight away it was obvious, so I set about stripping it back and rewiring it properly. Interestingly the OS one had obviously had the same issue and someone has bodged it with a crimp connector. I will clean that one up too.
Took some pictures on my phone to show the process. Will post them after this.
Stan - this should really be a wiki it's so useful and such an easy fix.
I don't get how a non moving part like this would consistently split? Discovery 4 HSE
Post #338372 21st Jul 2015 5:55pm
will wiki it Thumbs Up ... - .- -.
Post #338376 21st Jul 2015 6:02pm
wealy
Your Dad's car looks as though it spends a bit of its time off road!!
Post #338466 22nd Jul 2015 9:48am
wealy
Has anyone fitted the approved mod? Its about 40 quid from memory and I wonder if its worth it??
Post #338467 22nd Jul 2015 9:49am
What exactly is the approved mod? Is it worth it if the fix is so simple? Probably cost me 10p in bits. Discovery 4 HSE
Post #338469 22nd Jul 2015 9:52am
approved mod part = LR032839 wiring 2 of them cost 80,54 Euros + Vat here + another 150 Euros + Vat to do the job !!! Crying or Very sad All my spelling errorz are belong to me!
2024 RR Velar
2021 AM new Vantage
Post #338479 22nd Jul 2015 10:20am
this is the part
Post #338504 22nd Jul 2015 11:49am
Just an extension by the looks of it. Discovery 4 HSE
Post #338510 22nd Jul 2015 12:28pm
Stan that is the same price - you need 2 of them Razz Rolling Eyes Laughing Laughing Laughing All my spelling errorz are belong to me!
2024 RR Velar
2021 AM new Vantage
Post #338512 22nd Jul 2015 12:31pm
They fitted the updated part to the 2012 -> models as mine has it and it hasn't been done under warranty. Instead of the cable being a couple of wires wrapped n taped it is a thicker rubber wire into the grommet. Looks pretty sturdy tbh. There is nothing that can't be fixed with a hammer😜😜
Post #338549 22nd Jul 2015 4:53pm
Looks like the same grade wire but in a shrink wrap sleeve to make it tougher. Discovery 4 HSE
Post #338632 22nd Jul 2015 11:36pm
More like a rubber flex (like you would get on a power tool) than wires with heat shrink. There is nothing that can't be fixed with a hammer😜😜
Post #338639 23rd Jul 2015 7:22am
Mr Tee
Scotland 2019 Range Rover SVAutobiography 5.0 SC V8 Waitomo Grey
Mine has just bonged with this message, hopefully easy fix as noted! can anyone who has soldered comment if they have had further issues or is it best for the upgraded part as listed by Stan?
Cheers. Thumbs Up
Post #361521 10th Dec 2015 2:27pm
silversurfer
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Orkney Grey
Having soldered both sides and then only to have a second additional break occur I bit the bullet and ordered two new replacement kits Just as well because the wire insulation was badly cracked in several places, and the fault reappeared again a few days later.
The replacements are now in situ, and no more worries. Well worth it, or it was to me. Thumbs Up Thumbs Up
Post #361535 10th Dec 2015 4:02pm
Mr Tee
Perfect, ordered from Dan
Post #361544 10th Dec 2015 4:46pm
