![]() | Home > Technical (L322) > HEATED STEERING WHEEL L322 VOGUE |
BOBCUSSEN Member Since: 25 Nov 2012 Location: DORDOGNE Posts: 296 ![]() ![]() ![]() |
hi folks
sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 612 ![]() ![]() ![]() |
Mine is working and is always red. Never needed to hold it, just a simple push does it. Ed |
HI? when you push it, does the red light stay on?, as if i press mine and let it go, the light comes on then goes out again. if i hold it down, the same happens, ie the light comes on then goes out |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7976 ![]() ![]() ![]() |
Yes - push momentarily and it stays on - red all the time - press again & it goes off |
What he said ^^^ Ed |
well it doesent stay on when i push it so i guess it needs a new heater element or wheel?
Robert Member Since: 25 Oct 2011 Location: Perigueux Posts: 2290 ![]() ![]() ![]() |
Mine stays on, might be a temp. triggered issue. As soon as it gets hot it shuts down |
yes perhaps it has to be below a certain temp to trigger , just like the fuel burner ? but i have tried it in the dead of winter and has always done the same as it does now? so probably u:s |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16315 ![]() ![]() ![]() |
There is an ECU box in the steering wheel behind the Airbag... Probably unserviceable sir |
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 ![]() ![]() ![]() |
I have exactly the same problem, press the button and light comes on then goes straight off again. It's the heater element broken, so need to get a replacement wheel.
ok ; that explains it i expect. i dont think it warrents paying out for another wheel, just to get the heating working.
J90 Member Since: 02 Jul 2013 Location: Somewhere south of Bergerac Posts: 651 ![]() ![]() ![]() |
Buy a nice pair of driving gloves. Keep your hands warm and save money |
GOOD idea |
Have you thought it might be a faulty switch?
