Home > Technical (L322) > HEATED STEERING WHEEL L322 VOGUE |
v8rich Member Since: 28 Dec 2013 Location: Healing, Lincolnshire Posts: 67 |
I'm after a heated wheel 'ecu', for the final piece in my heated wheel upgrade.. |
9th Feb 2015 6:57pm |
Righto, will keep an eye out for that. It's a bit lower down the priority list atm. |
9th Feb 2015 7:04pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
Thanks Mate, you've made my day
9th Feb 2015 7:05pm |
My heated wheel stayed on for the whole journey tonight, 50 minutes
13th Feb 2015 8:07pm |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2257 |
Mine stays on till either switched of or ignition turned off and like Pete the stitching doesn't get too hot was only complaining to SWMBO about that this morning |
13th Feb 2015 8:34pm |
Slow Member Since: 09 May 2015 Location: Inverness Posts: 39 |
Bit of a thread revival but, my heated steering wheel does exactly what you described. Press it on and it almost instantly goes off.
22nd May 2015 3:27pm |
Jammer600 Member Since: 31 Mar 2013 Location: Bath Posts: 212 |
My steering wheel light also comes on when pushed and off when released but only recently, prior to this it stayed on until the ignition was turned off. So for a fix what has to be bought? Any links at all? Mines a 2005? |
6th Jun 2015 5:06pm |
babagee Member Since: 15 Feb 2015 Location: Somewhere between St. Helens & Kazakhstan Posts: 142 |
Hi
8th Aug 2015 8:16pm |
