Home > In Car Electronics (L322) > Retrofiting a Bluetooth ULF Module
Page 6 of 7 <1234567>
MrP
England 2011 Range Rover Autobiography 5.0 SC V8 Santorini Black
What's the sound quality like for those that have done the gen13 upgrade? Mine's awful Laughing I've changed to the latest mic etc but sound level and quality for the caller is bad. Anyone know if it's possible to adjust this somehow? "On first name terms with my local Dealer......now."
'61 Plate 5.0SC Autobiography - in Black ——— Gone
'53 plate 4.4V8 Vogue Bonatti Grey inside and out. ----- Gone
Post #306017 18th Jan 2015 10:55am
mjdronfield
My gen 6 is fine, which does not help I know.
I take it you have the microphone installed the right way round ?
If it's the later one, it should be noise cancelling.
Other than that, I wonder about swapping the wires on the ulf.....or checking good connections.... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #306026 18th Jan 2015 11:57am
MrP
Fairly sure I have the mic the correct way round with the arrow on it pointing the way I it said (towards the front of the car). "On first name terms with my local Dealer......now."
Post #306040 18th Jan 2015 12:43pm
cropps
England 2002 Range Rover Vogue 4.4 V8 Java Black
Sorry to hijack the thread but I have just fitted a BMW ulf to my 2002 vogue, done the rep in stuff, fitted the aerial etc. it all seems to work apart from the fact that I can't get any sound when the phone is connected. I can be heard but I cannot hear the caller, any ideas any one? I did have pins 37 & 38 the wrong way round at first, I hope this hasn't affected it.
Cheer's. Neil
Post #307895 25th Jan 2015 6:16pm
cropps
Finally sorted the sound problem, had to wait for a nice day & today was it! I was sure there had been some sort of telephone system in the car before as there was an extra mic on the roof. So this morning I started to take the dash apart to try & find out what had been fitted befor, it turns out that there was a Nokia phone kit installed but the cradle had been removed. There is a extra type cover panel on the centre console by the drivers feet, I think this was used to cover the cradle. Behind the panel was the plug for going into a cradle. All of this was hard wired into the Range Rover loom with some wires just cut & not used, speakers I think, any way after a while soldering in very tight places, everything was as it should have been before the kit had been installed. Next was to rebuild dash etc. all went well & success we have sounds out of the front speakers, it doesn't seem to cut the radio out but at least it works.
I don't know if this will help anyone but I just wanted to follow up my own question, there is nothing worst than reading a post that is left unfinished!!!
Cheer' Neil
Post #316764 7th Mar 2015 9:12pm
mjdronfield
Well that's a start then Neil.
I'm sure you will be able to find the phone mute wire on the ULF and feed it to the bm54. It should all work properly, but as you say, if other bits have been added previously you'll have to do some tracing of wires.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #316766 7th Mar 2015 9:22pm
cropps
Works fine when you have the mute wire in the right place!
Post #317557 11th Mar 2015 8:20pm
mjdronfield
Laughing yeah.....
Is it all working fine now ?
Does your ULF say mit ses on it, as it will allow voice control if it's activated. Hold the button down on the steering wheel and see if you get a beep.......
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #317558 11th Mar 2015 8:22pm
cropps
Hi
Yes it is the voice control version but I haven't got round to playing with it yet. Bust few days ahead, going on my Land Rover experience day tomorrow & then Geneva on Friday for the motor show so the other half has my days planned! Hi u doesn't include playing with the rangie.i will try it soon though & report back. Cheers Neil
Post #317585 11th Mar 2015 10:36pm
cropps
Land Rover experience day was awesome. You need to have great faith in the vehicles but taking your feet off the pedals & letting the Range Rover take you down impossibly steep hills takes a bit of coming to terms with! It was well worth the trip.
Post #318193 15th Mar 2015 9:17pm
mjdronfield
Yes, I did one at Eastnor Castle. It was ace....
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #318194 15th Mar 2015 9:20pm
Andy
Sorry to resurrect the thread...
My ULF has a burnt out power pin. I've bought another ULF and the feed that went to that pin is pin 17. It's red/yellow. I've just checked and there's no power from it. The fuse in f22 had blown so I replaced that but there's still no output from that wire.
Any one know of any other fuses in the system?
Thanks
Post #354481 28th Oct 2015 1:56pm
Lukie
2002 Range Rover Vogue 4.4 V8 Zambezi Silver
thank you all for this thread, I have partly installed my bluetooth UFL module today, unit in the boot need to find a way to secure it (it came with a bmw mounting bracket) ordered tonight mic and antenna fingers crossed that will be everything then, I did plug in first without the rewire, luckily just blew a fuse
Post #409340 14th Oct 2016 9:55pm
Lukie
to all that has done the ULF upgrade, does anyone have a Samsung S7 and does it work ?
if so what version of ULF are you using ?
I installed 1 today guessing a 3rd gen but not 100% at the min I used navcoder to force pairing which looked successful but the phone doesn't do anything if I ring off the phone it doesn't transfer to the car, if I dial from the car nothing happens
Post #420810 2nd Jan 2017 8:29pm
Lukie
just to update anyone reading this, I think I had a 3rd gen bluetooth module fitted (will confirm the numbers) I then found a 7th gen on ebay (don't think the seller did his homework) collected it today £60 the 7th gen works with my samsung S7 no problems, the voice control also seem to work well to, very happy now
thanks to others for pin out re wire instructions
will soon be offering for sale the old bluetooth unit for anyone needing one for an older phone
Post #421011 3rd Jan 2017 8:44pm
