![]() | Home > In Car Electronics (L322) > Retrofiting a Bluetooth ULF Module |
MrP Member Since: 28 Apr 2010 Location: West Sussex Posts: 471 ![]() ![]() ![]() |
What's the sound quality like for those that have done the gen13 upgrade? Mine's awful |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7899 ![]() ![]() ![]() |
My gen 6 is fine, which does not help I know.
Fairly sure I have the mic the correct way round with the arrow on it pointing the way I it said (towards the front of the car). "On first name terms with my local Dealer......now."
cropps Member Since: 07 Aug 2014 Location: Lancashire Posts: 32 ![]() ![]() ![]() |
Finally sorted the sound problem, had to wait for a nice day & today was it! I was sure there had been some sort of telephone system in the car before as there was an extra mic on the roof. So this morning I started to take the dash apart to try & find out what had been fitted befor, it turns out that there was a Nokia phone kit installed but the cradle had been removed. There is a extra type cover panel on the centre console by the drivers feet, I think this was used to cover the cradle. Behind the panel was the plug for going into a cradle. All of this was hard wired into the Range Rover loom with some wires just cut & not used, speakers I think, any way after a while soldering in very tight places, everything was as it should have been before the kit had been installed. Next was to rebuild dash etc. all went well & success we have sounds out of the front speakers, it doesn't seem to cut the radio out but at least it works.
Well that's a start then Neil.
Works fine when you have the mute wire in the right place! |
Hi
Land Rover experience day was awesome. You need to have great faith in the vehicles but taking your feet off the pedals & letting the Range Rover take you down impossibly steep hills takes a bit of coming to terms with! It was well worth the trip. |
Yes, I did one at Eastnor Castle. It was ace....
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2944 ![]() ![]() ![]() |
Sorry to resurrect the thread...
Lukie Member Since: 27 Sep 2016 Location: Liverpool Posts: 433 ![]() ![]() |
thank you all for this thread, I have partly installed my bluetooth UFL module today, unit in the boot need to find a way to secure it (it came with a bmw mounting bracket) ordered tonight mic and antenna fingers crossed that will be everything then, I did plug in first without the rewire, luckily just blew a fuse |
to all that has done the ULF upgrade, does anyone have a Samsung S7 and does it work ?
just to update anyone reading this, I think I had a 3rd gen bluetooth module fitted (will confirm the numbers) I then found a 7th gen on ebay (don't think the seller did his homework) collected it today £60 the 7th gen works with my samsung S7 no problems, the voice control also seem to work well to, very happy now
