![]() | Home > Maintenance & Mods (L322) > Gearbox flush |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3658 ![]() ![]() |
Well forgive me for not being psychic and knowing which Hang Over you've got, at the beginning there were a lot of posts from fellow tractor drivers |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1784 ![]() ![]() |
I have flushed boxes as low as 50k, and as high as 120k, with no issues. But the cars had no issues to begin with, other than 1 car, it was all preventative maintenance |
I run the car until the oil is up to 35 degrees, carry out the flush, disconnect the machine, start the car and top up, then let the car warm up to 35 degrees again, and recheck. As per the ZF instructions |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7970 ![]() ![]() ![]() |
So I have a 100k miler, that I'm fairly sure has never had the gearbox touched. Should I flush it, change what oil I can & fit a new filter, or return to blissful ignorance & wait for something to go bang ? 2007 3.6 TDV8 |
At 100k, you should be fine with just a flush.
nicedayforit, there is no set rule as to when to change the oil in your box, My car managed 102k and was still driving, BUT, I'd got those rumbling vibrations, from the rear end between 30 - 50. This is a very good sign that it's all going to go Pete Tong very soon |
sodalis Member Since: 18 May 2014 Location: Flintshire Posts: 26 ![]() ![]() ![]() |
I have recently had my gearbox serviced (full flush) at ZF in Dortmund at 100k miles. As far as I know, looking through the documentation that came with the car, this is the first time the oil has been changed.
But, you do have a 6 speed box not a 5 speed which is more problematic sir... |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
It's really annoying (to me) that auto boxes don't nowadays have drain screw in the torque converter. I have seen a few real old cars With them. And on an old rover I had, I actually drilled a small 3/16 hole and drained it, and welded up the hole! This would give the gearbox a better chance to dump it's 'filth' out in one sitting.
Hi Craig, I accept that but the thread doesn't really distinguish enough and for non-experts like me, it is confusing and worrying when one reads some of the views and stories. I'm not sure it helps if we end up believing one might as well not bother as it's already probably too late.
I agree... Lots of expert advice............... given by non experts me finks sir... |
I have taken steps to highlight GM in the above post so as not to confuse anyone, and for those of you who are still a bit foggy, if you pay more than £300 per annum road fun licence, or whatever they are calling roadtax this week, the chances are you have a ZF box. Which is stronger that the GM |
For clarity Craig, who would you be referring too? ![]() |
