Home > Maintenance & Mods (L322) > Gearbox flush |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
Well forgive me for not being psychic and knowing which Hang Over you've got, at the beginning there were a lot of posts from fellow tractor drivers
29th Nov 2014 7:29pm |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1776 |
I have flushed boxes as low as 50k, and as high as 120k, with no issues. But the cars had no issues to begin with, other than 1 car, it was all preventative maintenance
29th Nov 2014 8:09pm |
I run the car until the oil is up to 35 degrees, carry out the flush, disconnect the machine, start the car and top up, then let the car warm up to 35 degrees again, and recheck. As per the ZF instructions |
29th Nov 2014 9:22pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7953 |
So I have a 100k miler, that I'm fairly sure has never had the gearbox touched. Should I flush it, change what oil I can & fit a new filter, or return to blissful ignorance & wait for something to go bang ? 2007 3.6 TDV8 |
29th Nov 2014 9:37pm |
At 100k, you should be fine with just a flush.
29th Nov 2014 9:46pm |
29th Nov 2014 9:51pm |
nicedayforit, there is no set rule as to when to change the oil in your box, My car managed 102k and was still driving, BUT, I'd got those rumbling vibrations, from the rear end between 30 - 50. This is a very good sign that it's all going to go Pete Tong very soon
29th Nov 2014 11:35pm |
sodalis Member Since: 18 May 2014 Location: Flintshire Posts: 26 |
I have recently had my gearbox serviced (full flush) at ZF in Dortmund at 100k miles. As far as I know, looking through the documentation that came with the car, this is the first time the oil has been changed.
1st Dec 2014 9:43pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16300 |
But, you do have a 6 speed box not a 5 speed which is more problematic sir... |
1st Dec 2014 9:51pm |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2033 |
It's really annoying (to me) that auto boxes don't nowadays have drain screw in the torque converter. I have seen a few real old cars With them. And on an old rover I had, I actually drilled a small 3/16 hole and drained it, and welded up the hole! This would give the gearbox a better chance to dump it's 'filth' out in one sitting.
1st Dec 2014 10:21pm |
Hi Craig, I accept that but the thread doesn't really distinguish enough and for non-experts like me, it is confusing and worrying when one reads some of the views and stories. I'm not sure it helps if we end up believing one might as well not bother as it's already probably too late.
1st Dec 2014 10:24pm |
I agree... Lots of expert advice............... given by non experts me finks sir... |
1st Dec 2014 10:33pm |
I have taken steps to highlight GM in the above post so as not to confuse anyone, and for those of you who are still a bit foggy, if you pay more than £300 per annum road fun licence, or whatever they are calling roadtax this week, the chances are you have a ZF box. Which is stronger that the GM but will need to be power flushed at the point of oil change
1st Dec 2014 10:45pm |
For clarity Craig, who would you be referring too? |
2nd Dec 2014 6:58am |
