Home > In Car Electronics (L322) > 2002-2006 Replacement head unit running Android |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
I agree with those sentiments Dave, life would be very boring if there was only one solution, plus it would probably mean that some git has got there first and copy righted it! Yesterday I couldn't spell Engineer... Today I are one!
13th Nov 2014 11:08pm |
ironhorse Member Since: 13 Dec 2013 Location: birmingham Posts: 355 |
correct me if im wrong but are you missing the point
14th Nov 2014 6:49pm |
Trans.am Member Since: 14 Nov 2014 Location: Grimsby Posts: 1 |
Hi Haylands . Could I give you a call about your upgrade . I live in Grimsby so not too far away
14th Nov 2014 6:50pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7799 |
I don't think there is anyone contributing to this thread that doesn't like the android head unit.
14th Nov 2014 7:43pm |
Steverr Member Since: 27 Oct 2013 Location: Bristol Posts: 191 |
Ok, I am one confused plumb!!!
14th Nov 2014 8:30pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8207 |
Email sent SteveRR because it dosen't work like that... unless you have an HSE without the head unit with a screen, then you can plug it in at the front.... On the Vogue spec ones it is just a screen, the radio/TV/CD/amp/GPS units are all in the boot so you have to get back there to wire it in.... well the CD is in the glove box but you get the idea..... Pete __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Parchment over Navy Interior. Sold 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand, Jet Interior. Sold 2002 L322 Vogue 4.4 V8 Epson Green, Ivory over Aspen Interior (Fatty Offroader) Sold -Click for Project Fatty off roader- |
14th Nov 2014 8:41pm |
Because the connectors on the original head unit feed to the rear of the car where the action happens. It's really only a screen. The speakers are fed from the amp in the boot with a channel dedicated to the frequency the speaker its connecting to is made to reproduce. The amps need the original screen to tell them to power on. If you remove it and connect the android unit to the amps, you will get no sound. The amps will be off.
14th Nov 2014 8:44pm |
Sorry Pete, I'm a slow typist..... 2011 Range Rover Vogue SE 4.4 TDV8
14th Nov 2014 8:47pm |
Okie dokie.... now we're cooking. Thank you |
14th Nov 2014 9:12pm |
Don't get me wrong, it's doable, but we have been discussing the best way of interfacing to the existing kit, which is why there are a number of options and theories, and people focussing in on different areas to find some answers. 2011 Range Rover Vogue SE 4.4 TDV8
14th Nov 2014 9:18pm |
ironhorse, bud, I already have Bluetooth, Ipod with full steering wheel control, reversing camera, and I still have the original factory setup save the CD changer. I also have a very good satnav which is touch control and has full Traffic backup. I do not however have a TV or a DVD player, yet, I am in possession of a DVT tuner and could add it in to the factory system. But that means more wires, a separate remote control to operate it, and Mono sound. I feel that is too much faffing around for too little return.
14th Nov 2014 9:27pm |
Ok I get it now. My problem is I have a dodgy dsp !! So was trying to get that out of the loop !,... So Im gonna have to get a new dsp or the repair from Baris.
14th Nov 2014 10:54pm |
Steve, unless your really into hifi then it sounds great wired in directly missing out the DSP amp, as for harming the speakers.... turning it up too loud would do more harm..... Pete
15th Nov 2014 1:08am |
magu Member Since: 22 Sep 2014 Location: Burton on Trent Posts: 28 |
I gave in...Very nearly got it working,managed to get cd playing and android unit on at same time but that's where it ended,decided its all gone a bit technical for me so ripped the lot out and used the short lead that came with the unit to do a trial run with everything in the boot and my cut n pasted spaghetti.wiring..worked fine sounds great...However...if you have a 2004 vogue and are intending to do this be prepared to do the following
15th Nov 2014 4:16pm |
