![]() | Home > In Car Electronics (L322) > 2002-2006 Replacement head unit running Android |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7877 ![]() ![]() ![]() |
Well that looks a nice thorough job.
Dave1946 Member Since: 23 Sep 2014 Location: Norfolk Posts: 35 ![]() ![]() ![]() |
Im happy to say that Im about done with installing everything.
Hopefully it will upload this time! |
posted fine now.
Just some ramblings to give food for thought.
If you are just talking crossovers, you don't need a channel per frequency range, not from the amp, unless you are going active.
I'm not sure if this is the correct thread for asking questions about actually using these head units, although Im sure someone will quickly tell me if not.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8396 ![]() ![]() ![]() |
I bought a 32gb mini sd card for the slot on the right, filled it with music files from my itunes and it plays them perfectly... I suggest you try that...
I was trying to keep the right hand micro disc for the Daily Roads Voyager to use Pete. But if push comes to shove that's what I'll have to do. Surly there must be music player software that will accept MP3 files fed from the USB without any hassel though. |
I use the other one that the satnav is on, bought a 32gb one for there as well... Pete
Doesn't it interfere with the sat nav files then?
You could always create a file for each song, a pain I know, but would work if Petes way is no good for you. It's just a text file that is named same as the song.
There is a music App on it that just looks in the right hand sd card for music, you can toggle to it with the bottom button (well, not the phone button, the one above) on the steering wheel, it toggles through the radio/video/dvd/music etc etc, the track advance buttons work with it as well...
