Home > Maintenance & Mods (L322) > Dead diagnostic socket
Page 1 of 4 1234>
For some reason my diagnostic socket appears to be "dead", can't get any readings at all from it.
Checked fuses 5 and 15 and they are fine.
Anyone else had this problem?
Post #267585 27th Jun 2014 8:17am
pld118
I'll have to make a complaint to LRUK ndf for denying us the full ownership experience as that's about the only problem we've not encountered! Rolling with laughter
Apologies, ahem, thread interruption over Embarassed
OP was:
" Dead diagnostic socket
Anyone else had this problem? "
Post #267616 27th Jun 2014 12:19pm
Dolphinboy
United Kingdom 2015 Range Rover Autobiography SDV8 Baltic Blue
Check the wire connection behind the dash/bulkhead. They can sometime wear through or drop out.
Post #267630 27th Jun 2014 1:31pm
@ pld 118
Had my hopes up there you knew the answer to my problem. Thumbs Up Laughing
@Dolphinboy
Thanks I'll have a look tomorrow Thumbs Up
Post #267658 27th Jun 2014 3:44pm
bent pin? ... - .- -.
Post #267685 27th Jun 2014 5:57pm
GraemeC
United Kingdom 2007 Range Rover Vogue SE TDV8 Zermatt Silver
Let us know how you get on - I recall a conversation with the chaps at AJR where I get my car serviced
Same problem, diagnostics totally dead. IIRC it was due to a short circuit in the electrics which monitor the front headlight bulb Question
I only recall it vaguely, but they were amazed such a small issue could result in the diagnostics being totally dead
If you can't resolve it, post up and I'll get on the phone and ask what the exact problem/solution was Thumbs Up 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car!
Post #267712 27th Jun 2014 7:46pm
Well, checked for wires broken, dropped out and bent pins found nothing so the socket is still dead although it does have 12V+ and earth.
Never had any problems using it before.
The reason I was using this time is the parking sensors are playing up now and again insofar as when the are working they sometimes emit a continuous tone when they shouldn't. I suspect a corroded connection behind one of the bumpers but was just checking first using the diagnostics.
@ Graeme, I would appreciate any help you could give via your AJR contact, an indication of the type of fault that would cause the socket to malfunction would be very helpful. Thumbs Up
Post #267967 29th Jun 2014 10:13am
you've obviously done a battery reset i suppose? Wink ... - .- -.
Post #267969 29th Jun 2014 10:33am
First thing Stan, without fail. Thumbs Up
Post #267971 29th Jun 2014 10:35am
i was kinda thinking you would have Laughing ... - .- -.
Post #267972 29th Jun 2014 10:35am
could it be the actual obd reader? ... - .- -.
Post #267973 29th Jun 2014 10:36am
adigorn
+1 for headlight leveling ecu
defo check for corrosion and damage
Post #267981 29th Jun 2014 11:41am
but good point from stan about the reader, do you have an alternative to try ? .
Post #268004 29th Jun 2014 3:52pm
Have tried a Hawkeye, the display lights up but no sinage.
Have also tried RSW All Comms, the system transmits ok but nothing is received back with the system showing error.
This happens on all ECU's which I wouldn't have expected.
Will definitely investigate the headlamp leveling ECU and leveling motors tomorrow and see what that brings.
Apart from obvious corrosion to connectors I presume there is no way of testing the ECU?
Post #268014 29th Jun 2014 4:10pm
Diagnostic tool ? Laughing Twisted Evil
Hope you get it sorted, I would be lost without my OBD port Embarassed .
Post #268015 29th Jun 2014 4:11pm
Page 1 of 4 1234>
