![]() | Home > Maintenance & Mods (L322) > Dead diagnostic socket |
I'll have to make a complaint to LRUK ndf for denying us the full ownership experience as that's about the only problem we've not encountered! |
Check the wire connection behind the dash/bulkhead. They can sometime wear through or drop out. |
@ pld 118
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35487 ![]() ![]() |
bent pin? ... - .- -.
GraemeC Member Since: 01 Jul 2012 Location: Chester Posts: 836 ![]() ![]() ![]() |
Let us know how you get on - I recall a conversation with the chaps at AJR where I get my car serviced
Well, checked for wires broken, dropped out and bent pins found nothing so the socket is still dead although it does have 12V+ and earth.
you've obviously done a battery reset i suppose? |
First thing Stan, without fail. |
i was kinda thinking you would have |
could it be the actual obd reader? ... - .- -.
adigorn Member Since: 18 Mar 2010 Location: West Midlands/Birmingham Posts: 204 ![]() ![]() |
+1 for headlight leveling ecu
but good point from stan about the reader, do you have an alternative to try ? .
Have tried a Hawkeye, the display lights up but no sinage.
Diagnostic tool ? |
