Home > Maintenance & Mods (L322) > Dead diagnostic socket |
its me Member Since: 08 Mar 2013 Location: southampton Posts: 78 |
That also happens on mine when I was removing the dash. Had to pull a fuse to turn them off. 2011 4.4 tdv8 Kahn. 2007 supercharged with 2012 lights and overfinch body kit. P38 with a full J.E.Engineering conversion |
10th Jul 2014 7:32am |
SteveMFr Site Sponsor Member Since: 22 Nov 2009 Location: Strasbourg, France Posts: 1641 |
Hi NDFI,
10th Jul 2014 8:02am |
RCusden Member Since: 12 May 2012 Location: NarberthPembrokeshire Posts: 186 |
Hi ndfi.
6th Apr 2016 11:58am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3978 |
I am ashamed to say I haven't resolved the problem unfortunately, partially compounded by the fact my car is running well and I have had no reason to date to urgently resolve the issue.
6th Apr 2016 4:30pm |
I have only just managed to download rave and look through the wiring diagrams. As far as I can see ports 4 and 5 are earths and will check them. I guess I have been lucky that every fault I have had with my ffrr some one has had before and posted the answer. Maybe this is my time to contribute.
6th Apr 2016 5:03pm |
le25dse Member Since: 15 Jan 2012 Location: Oslo Posts: 78 |
I wrote a post on this subject under the "electronics section". See the last post in this thread:
6th Apr 2016 5:15pm |
Thank you for the link I have watched the YouTube clip and checked the connections. Below is what I have on each port.
6th Apr 2016 8:30pm |
From my memory pin 8 should have between 3,5 and 4 volt with ignition on. I suggest you start unplugging the ecu's one by one and see if you can isolate where the fault is. ----------
6th Apr 2016 9:15pm |
A bit of an update and a cry for help. I have disconnected the abs ecu , transfer box ecu , LCM module , steering sensor and the headlamp ecu.
12th Apr 2016 8:58pm |
I have 6.35V on pin 8 with the ignition off and 8.5V with the ignition on.
13th Apr 2016 9:08am |
