Home > Maintenance & Mods (L322) > Dead diagnostic socket |
GraemeC Member Since: 01 Jul 2012 Location: Chester Posts: 836 |
I will give AJR a call tomorrow - it may well have been the headlamp self levelling ECU, I'll find out how they resolved it and post their solution 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car! |
29th Jun 2014 4:16pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3978 |
Thanks |
29th Jun 2014 5:13pm |
adigorn Member Since: 18 Mar 2010 Location: West Midlands/Birmingham Posts: 204 |
Its usually can short killing all comms
29th Jun 2014 9:13pm |
Well, just spent an hour looking for the elusive headlamp leveling ecu, no sign of it, turns out that according to RAVE it was only fitted to cars with Vin numbers 2A100042-3A117361.
30th Jun 2014 10:08am |
passenger (LHS) A pillar (under little plastic cover under dash)
30th Jun 2014 11:15am |
Which plastic cover, the black one with the footwell light in it or the black trim that sits vertically around the bottom of the door opening? Doesn't seem to be in either position, certainly no pink connectors. My Vin is 4A.....
30th Jun 2014 11:48am |
you are looking in the right place seems no luck this time |
30th Jun 2014 5:32pm |
The holes for mounting the ecu are in the side panel and it appears there is a headlight level ecu is fitted somewhere as the cables go into each of the headlights unless the harness wasn't modified when the ecu was omitted.
30th Jun 2014 5:43pm |
PatGAPInnov Site Sponsor Member Since: 01 Dec 2011 Location: Montreal Posts: 153 |
Try the following, turn the key to the ON position and proceed with measuring the voltage between pin 5 and 8 of the OBD port using a volt meter. Repeat the same process between pin 5 and 7.
1st Jul 2014 7:11pm |
Yes I can do that, can you tell me which way the pins are numbered.
1st Jul 2014 8:21pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6409 |
Does this help ?
1st Jul 2014 8:30pm |
Certainly does help, Thanks
1st Jul 2014 8:39pm |
Wow........me..........helping NDFI with an electrical problem .
1st Jul 2014 8:42pm |
2008 MY Supercharged
2nd Jul 2014 1:24am |
