Home > Maintenance & Mods (L322) > Dead diagnostic socket
Page 3 of 4 <1234>
PatGAPInnov wrote:
Try the following, turn the key to the ON position and proceed with measuring the voltage between pin 5 and 8 of the OBD port using a volt meter. Repeat the same process between pin 5 and 7.
Cheers
Voltages measured as followed
Pins 5-7 11.15V
Pins 5-8 8.65V
These with the battery voltage at 12.6V
Post #268531 2nd Jul 2014 8:38am
PatGAPInnov
Site Sponsor
Canada 2010 Range Rover Autobiography 5.0 SC V8 Causeway Grey
I would verify the connection between Pin 8 of the OBD connector and the instrument pack C0233-1. White and purple wire. We've seen a few cases of damaged wires that would prevent the DS2 from working.
Post #268882 3rd Jul 2014 3:11pm
Thanks Pat, I'll check that tomorrow. Thumbs Up
Post #268895 3rd Jul 2014 4:59pm
Finally got round to checking the continuity of the White/Purple wire from the diagnostic socket to the CO233-1 connection on the instrument panel. All ok, back to the drawing board. Big Cry
Post #269863 9th Jul 2014 10:04am
i'm embarrassed to suggest this to a man who is pretty clever with stuff but, did you have the engine running? ... - .- -.
Post #269868 9th Jul 2014 10:09am
Didn't need the engine running stan, just checking the wire wasn't broken anywhere and is connected at both ends. Thumbs Up
Too hot now to carry on putting the car back together.
Post #269873 9th Jul 2014 10:28am
sorry , i meant when you had the obd reader inserted and got the dead socket..... ... - .- -.
Post #269877 9th Jul 2014 10:35am
Yes, the engine was running each time I was plugged in. Thumbs Up
Bit of a problem this, could take a long time to resolve, unfortunately.
Post #269880 9th Jul 2014 10:43am
i thought you would have,
did you disconnect both headlights and try? ... - .- -.
Post #269885 9th Jul 2014 11:10am
Certainly did. Thumbs Up
The suspect problems are the two headlight ecu's the headlight self levelling ecu and breaks to one of the wires at the socket.
Checked them all bar the self levelling ecu which my car appears not to have even though the wires are at the headlights. If my car has this ecu it appears to be mounted away from the position in which it 's connector normally corrodes due to water so with a bit of luck it's not the problem even if I can't find it. Smile
At the end of the day I think this is probably corrosion at a connector, the problem is where.
Post #269896 9th Jul 2014 11:34am
if you cant find that ecu , how about pulling the fuse for it? ... - .- -.
Post #269899 9th Jul 2014 11:45am
I've pulled every fuse on the car to date but I must admit I haven't tried pulling ECU fuses and switching on the ignition.
Not sure what might happen if I did. Have to have a think about that.
Post #269908 9th Jul 2014 12:03pm
PatGAPInnov
Site Sponsor
That would be the next logical step, trying to isolate the defective ECU.
Post #269967 9th Jul 2014 7:31pm
SteveMFr
Site Sponsor
As Patrick says, this is the next step in isolating the problem. What could happen is that you get an additional fault code - possibly with a warning light (such as the airbag). These will need to be cleared - once the diagnostic socket is brought back online Rolling Eyes
I had dead diagnostics due to water in my bluetooth module. Do you have any systems on the car that are not functioning to 100%?
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #270037 10th Jul 2014 6:26am
I have no reason to believe anything on the car is not operating correctly which is why I am a bit reluctant to start pulling fuses on ECU's only to cause a fault which at least for now I can't clear.
From your experience of such matters are there any ECU's I definitely shouldn't disable as a fault will definitely log. I'm think particularly of the LCM which seems to dabble in everything.
Initially I will list all the ECU's on the car and respective fuses and take it from there, obviously a lot of them will have no operating consequences even if a fault is logged.
One interesting thing I noticed yesterday, when I un-plugged the main lighting switch as part of my dashboard dismantling all the side lights lit up even though they were off when the switch was un-plugged. Plugging the switch back in switched them off.
Tried this a few times and each time I un-plugged the switch the sidelights came on. The switch was in the off position all the time. Can't for the love of me figure this out. Smile
Given that everything is working correctly I still have a suspicion that corrosion in a connector affecting one of the bus systems could well be the cause of the problem. Obviously most of the ECU's are inboard on the car and simply not liable to damp damage. Initially I intend to look in the rear back compartment although again I have no reason to suspect water damage.
Post #270042 10th Jul 2014 7:11am
Page 3 of 4 <1234>
