Home > Technical (L322) > IIDtool :) |
mike37 Member Since: 17 Nov 2013 Location: East Mids Posts: 36 |
Group buy.
28th Feb 2014 10:09pm |
Ipslore Member Since: 21 Apr 2013 Location: St Helier Posts: 39 |
@Duckworth - yes would join group buy for BT version. |
28th Feb 2014 10:53pm |
g4alan Member Since: 03 Jul 2012 Location: Whitehaven Posts: 18 |
Hi Dan I would also be interested in a group buy for a 2005 BT version of the IID Tool.
1st Mar 2014 2:06am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35438 |
87RJD, 'lazy lock from the remote handset' should do that for number 1 and if you have already done that try again maybe the config didnt load up properly ,
1st Mar 2014 6:16am |
Paul_H Member Since: 17 Dec 2013 Location: Bracknell Berks Posts: 126 |
Thanks Stan, looks like i'm in the market for one of these 2005 Range Rover Vogue with Supercharged Accessories GONE 2001 Discovery TD5 ES GONE 1995 Discovery 300 tdi GS |
1st Mar 2014 7:43am |
Shandonman Member Since: 02 Dec 2013 Location: Argyll Posts: 90 |
If your looking at numbers for a group buy, count me in for a B/T unit 2002 Vogue 4.4 V8
1st Mar 2014 6:58pm |
group buy available here,
3rd Mar 2014 11:30am |
paulmoran2 Member Since: 27 Nov 2013 Location: Leeds Posts: 1422 |
Pretty easy to navigate, but when I turned the TPMS off got a bit of a shock when the engine cut, the cluster lit up then everything died for 20 seconds, rebooted and all was well....can say that I nearly messed myself when that happened.
3rd Mar 2014 2:57pm |
5 you cant do, 6 should be CM [cold monitoring] and select the bulb, you might have to do HM [hot monitoring] as well.. |
3rd Mar 2014 3:52pm |
Which menu is that in Stan...looked in the LCM menu but couldnt see anything? GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
3rd Mar 2014 4:06pm |
yep, in the LCM menu,
3rd Mar 2014 4:25pm |
cliffy Member Since: 17 Apr 2010 Location: Surrey Posts: 556 |
wish my tool had the BT option |
4th Mar 2014 3:41pm |
help. Sorry if this is a daft question, but what is "Hot Monitoring" (HM) and "Cold Monitoring" (CM)....I know one of them (or both of them) checks the bulb to make sure its functioning, but could do with understanding before I play with the IID as wanting to switch off warning for front fogs as the wires are now just terminated / disconnected as the DRL switch is powering my DRL's now. GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus HAVE 1999 Discovery 2 GS 4.0 V8 - Silver - Off Road Toy GONE 2013 L405 4.4 SDV8 Vogue. Black with Silver roofline and 22" s HAVE 2015 Jaguar XF. |
6th Mar 2014 2:36pm |
cold monitoring is the ecu checking the bulb on start up, hot monitoring is when the bulb is on..switch both off for no dash errors.. ... - .- -.
6th Mar 2014 3:10pm |
