![]() | Home > Technical (L322) > IIDtool :) |
mike37 Member Since: 17 Nov 2013 Location: East Mids Posts: 36 ![]() ![]() |
Group buy.
Ipslore Member Since: 21 Apr 2013 Location: St Helier Posts: 39 ![]() ![]() ![]() |
@Duckworth - yes would join group buy for BT version. |
g4alan Member Since: 03 Jul 2012 Location: Whitehaven Posts: 18 ![]() ![]() ![]() |
Hi Dan I would also be interested in a group buy for a 2005 BT version of the IID Tool.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35527 ![]() ![]() |
87RJD, 'lazy lock from the remote handset' should do that for number 1 and if you have already done that try again maybe the config didnt load up properly ,
Paul_H Member Since: 17 Dec 2013 Location: Bracknell Berks Posts: 126 ![]() ![]() ![]() |
Thanks Stan, looks like i'm in the market for one of these 2005 Range Rover Vogue with Supercharged Accessories GONE 2001 Discovery TD5 ES GONE 1995 Discovery 300 tdi GS |
Shandonman Member Since: 02 Dec 2013 Location: Argyll Posts: 90 ![]() ![]() ![]() |
If your looking at numbers for a group buy, count me in for a B/T unit 2002 Vogue 4.4 V8
group buy available here,
paulmoran2 Member Since: 27 Nov 2013 Location: Leeds Posts: 1422 ![]() ![]() ![]() |
Pretty easy to navigate, but when I turned the TPMS off got a bit of a shock when the engine cut, the cluster lit up then everything died for 20 seconds, rebooted and all was well....can say that I nearly messed myself when that happened.
5 you cant do, 6 should be CM [cold monitoring] and select the bulb, you might have to do HM [hot monitoring] as well.. |
Which menu is that in Stan...looked in the LCM menu but couldnt see anything? GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
yep, in the LCM menu,
cliffy Member Since: 17 Apr 2010 Location: Surrey Posts: 556 ![]() ![]() |
wish my tool had the BT option |
help. Sorry if this is a daft question, but what is "Hot Monitoring" (HM) and "Cold Monitoring" (CM)....I know one of them (or both of them) checks the bulb to make sure its functioning, but could do with understanding before I play with the IID as wanting to switch off warning for front fogs as the wires are now just terminated / disconnected as the DRL switch is powering my DRL's now. GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus HAVE 1999 Discovery 2 GS 4.0 V8 - Silver - Off Road Toy GONE 2013 L405 4.4 SDV8 Vogue. Black with Silver roofline and 22" s HAVE 2015 Jaguar XF. |
cold monitoring is the ecu checking the bulb on start up, hot monitoring is when the bulb is on..switch both off for no dash errors.. ... - .- -.
