Home > Technical (L322) > IIDtool :)
Page 4 of 8 <12345678>
SteveMFr
Site Sponsor
Hi Stan,
No, you can drop or raise the vehicle as much as you like in one session - well, as much as is possible. We offer no limitations where others fail... Laughing JK
Goncalo, as you have a pre 2006 RR, you can adjust the heights of each level (access, motorway, standard, off road) separately. The later vehicles can only be adjusted together (all levels +10mm, etc.).
And you are not the only one who likes the RR taller. I even have taller tires too. But you have to realize that raising the center of gravity in your vehicle gives you less margin of error in extreme situations. We do not want to be held accountable if you do something silly with your raised RR and injure yourself or others. But we do want to provide the opportunity to be able to do more with your RR. It remains your responsibility if you raise the vehicle and drive on public roads. Neutral
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #243408 18th Feb 2014 6:13pm
thanks for the clarification Steve... Thumbs Up
nice FF btw.. Wink
Post #243415 18th Feb 2014 7:14pm
goncalo
Portugal 2007 Range Rover Vogue TDV8 Java Black
Thanks Steve!
Great FF Smile 2006 model!
I just want a little more taller, i donīt want to abuse!
Increase the hight don't compromise the lifetime of EAS?
Steve, we canīt buy directly from you, don't we?
Many Thanks,
Best Regards Ex-FULLFATTY now downgraded
L494 RRS P400e Dynamic Narvy Black
-------------------------------------- gone
6 | FF-RR 2007 TDV8 Vogue JAVA BLACK
5 | FF-RR 2003 TD6 Vogue Bonatti grey
4 | Ex-RR 2000 P38 automatic
3 | Ex-RR 1994 300tdi classic
2 | Ex-RR 1993 200tdi
1 | Ex-RR 1991 turboD VM engine
Post #243417 18th Feb 2014 7:16pm
supershuttle
Interesting set of posts, when I got my IIDTool I first used it to correct a low corner, then messed with heights. As mine is a 2007 as Steve points out you can only apply a blanket change which affects all heights i.e. 10mm lower (which mine is) is 10mm lower at Access, 10mm lower at Normal and 10mm lower at Extended. I did this because at the time you couldn't set the speed at which it lowers to a more appropriate value - things might have changed I will check if ever the Indy gives me my car back assuming they don't impound it because I can't pay the bill Laughing Geoff
Post #243421 18th Feb 2014 7:26pm
Paul_H
England 2005 Range Rover Vogue Td6 Tonga Green
When I had my Disco II, I had a Nanocom, which Iam guessing is very similar. It was fantastic for adjusting little things.
On the D2 Boys Club they have a map of people that have Nanocoms and that are happy to help other owners with diagnostics and adjusting settings.
Is there a list of people with IID tools that can help other owners (especially those who's SWMBO's have stopped their pocket money Big Cry ) 2005 Range Rover Vogue with Supercharged Accessories
GONE 2001 Discovery TD5 ES
GONE 1995 Discovery 300 tdi GS
Post #243432 18th Feb 2014 7:42pm
the idtool is vin locked so that wont work..
Post #243433 18th Feb 2014 7:44pm
Paul_H
Time to put on them trousers and tell her who's boss Shocked
or
Just leave the car as it is Wink 2005 Range Rover Vogue with Supercharged Accessories
Post #243441 18th Feb 2014 8:06pm
SteveMFr
Site Sponsor
Actually, if you read the VIN Lock post in the New Products thread at the top of the technical forum, you'll see that this policy is completely changed with the introduction of firmware 3.0
Essentially, once we finish adding the rest of the LR vehicle types later this year, the IIDTool BT will provide the capabilities of a Hawkeye Pro without VIN lock at less than 1/3 the price plus the advanced functions (CCF, calibrations, etc) with a VIN lock.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #243462 18th Feb 2014 8:28pm
rej
England 2006 Range Rover Vogue 4.4 V8 Zambezi Silver
If I turn on daytime running lights which lights will actually come on the xenon headlight or the sidelight? Are they adjustable as to brightness or just on or off? FYI I have the adaptive bi-xenon lights. There is a difference between knowing your sh!t and knowing you're sh!t
2005 Registered 2006 MY 4.4 AJV8 Range Rover Vogue
Post #243522 18th Feb 2014 9:57pm
SoggyBottoms
United Kingdom 2007 Range Rover Vogue Supercharged Zambezi Silver
I have mine set at 80%
Post #243540 18th Feb 2014 10:46pm
BUSAKAZ
England 2003 Range Rover Vogue Td6 Adriatic Blue
blueRR2006 wrote:
In my case, I like the BT option on tablet/smartphone, you can stand outside your RR to make EAS adjustments/modifications
Hi all,
new on here my question is does the llD tool BT work on a nokia 1020.
Many thanks
Kaz 2003 TD6
1996 4.6 hse (gone)
2000 200 BHP Hayabusa
Post #243650 19th Feb 2014 5:15pm
only ios and android afaik..
you can connect via usb to a laptop though..
http://www.gap-diagnostic.com/products.html
Post #243651 19th Feb 2014 5:18pm
BUSAKAZ
Thanks Stan Thumbs Up 2003 TD6
1996 4.6 hse (gone)
Post #243653 19th Feb 2014 5:22pm
paulmoran2
England 2013 Range Rover Vogue SDV8 Mariana Black
Santa made an early delivery..
This little beauty arrived this morning...Ģ270 from Island 4x4..Ordered Tuesday..great service.
 GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
HAVE 1999 Discovery 2 GS 4.0 V8 - Silver - Off Road Toy
GONE 2013 L405 4.4 SDV8 Vogue. Black with Silver roofline and 22" s
HAVE 2015 Jaguar XF.
Post #245442 28th Feb 2014 11:39am
and now the fun begins... Thumbs Up
Post #245456 28th Feb 2014 12:23pm
