Home > Maintenance & Mods (L322) > Range Rover L322 - Stuck in Extended or Off Road Height
Page 2 of 5 <12345>
They seem to clog to the point where they are a plug very suddenly!
Post #235297 16th Jan 2014 1:51pm
87RJD
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
Thanks for this info, my brothers TDv8 had this problem for a while, really simple fix when you know what to look for. His well chuffed, as its saved a rip off trip to a garage. Thanks
Post #235852 19th Jan 2014 1:20pm
Post #235863 19th Jan 2014 1:59pm
There is a modified part from LR (ask Dan) with a hole in it already... Been an issue for years Thumbs Up We check and change them on major services if still fitted with the old type... Approx £7 from main dealer If I remember correctly...
I'm sure Dan will ad a part number when he reads this thread...
Post #235868 19th Jan 2014 2:07pm
And very easy to drill your existing one....
Post #235871 19th Jan 2014 2:12pm
Why bother when you can fit an inexpensive new JLR approved part Rolling Eyes
Post #235873 19th Jan 2014 2:16pm
Because when it happens chances are you will not have the new JLR approved part. Drilling (or simply removing) takes a few minutes and your cured and can continue your journey (you may be in Outer Mongolia). By all means then order a spanking new JLR part Rolling Eyes
PS: If your fitting them nearly every day why don't you know the part number you must be getting them from JLR?
Last edited by Gazellio @ Prestige Cars on 19th Jan 2014 2:21pm. Edited 1 time in total
Post #235875 19th Jan 2014 2:19pm
Ok Gary... Well done you Rolling Eyes Yawn Banging Head
Post #235876 19th Jan 2014 2:21pm
If you make "rolling eye" comments on my threads please expect me to make common sense replies Smile Thumbs Up
Post #235877 19th Jan 2014 2:24pm
It's common sence for forum members to perform preventative maintenance and fit a revised inexpensive part before a breakdown situation in my eyes...
But hay ho, if you want to try to pick fault every post... Whatever!
Post #235879 19th Jan 2014 2:33pm
Sorry Craig I reminded poster of the simple drill fix in a friendly manner and YOU came in with rolling eyes?
Post #235881 19th Jan 2014 2:36pm
87RJD
OK, So does anyone know the part number for the modified filter, so I can order one in and fit it as preventive maintenance please, Or will Dan supply me 2 please?
Post #235996 19th Jan 2014 11:50pm
GraemeC
United Kingdom 2007 Range Rover Vogue SE TDV8 Zermatt Silver
Thanks Gaz, ordered from Amazon and replaced this morning - old filter wasn't too bad but air flows through the new filter a bit easier
Top bit of preventative maintenance Thumbs Up and for £3.50 I now have four spare filters!
Biggest part of the job was removing the spare - I think I will be purchasing an extraction kit from Dan! 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car!
Post #237038 25th Jan 2014 1:40pm
tassietd6
Australia
Same problem...different compressor?
G'day. I have a 2002 TD6 and have the same problem...the suspension is stuck at maximum height. I uncovered the compressor however not only does it not look like the one pictured n this thread but it also has a totally different filter. It has no hex. and looks like it can't be unscrewed.
Post #293360 16th Nov 2014 1:08am
Hi Tassie
Yes you have the earlier compressor model (like me) and like me the brass filter doesn't have a hex to easily remove. I had a go with some pliers but didn't try too hard as I didn't have a spare to hand, so not sure how easily it will come out or if it is on a thread!
You could always remove and drill out in situ as it were. Because it is an exhaust filter it will blow out any debris (?)
- [EDIT] done a bit of research, no thread on the early models, it is a ribbed press fit and wil take some tugging, turning and wobbling to get out.
Does your compressor run OK? Do you have any faults on dash or via diagnostics? Would seem a reset of some kind might clear things. Have you tried a battery disconnection? .
Post #293486 16th Nov 2014 2:29pm
Page 2 of 5 <12345>
