![]() | Home > Maintenance & Mods (L322) > Range Rover L322 - Stuck in Extended or Off Road Height |
They seem to clog to the point where they are a plug very suddenly! |
There is a modified part from LR (ask Dan) with a hole in it already... Been an issue for years |
And very easy to drill your existing one.... |
Why bother when you can fit an inexpensive new JLR approved part |
Because when it happens chances are you will not have the new JLR approved part. Drilling (or simply removing) takes a few minutes and your cured and can continue your journey (you may be in Outer Mongolia). By all means then order a spanking new JLR part |
Ok Gary... Well done you |
If you make "rolling eye" comments on my threads please expect me to make common sense replies |
It's common sence for forum members to perform preventative maintenance and fit a revised inexpensive part before a breakdown situation in my eyes...
Sorry Craig I reminded poster of the simple drill fix in a friendly manner and YOU came in with rolling eyes? |
87RJD Member Since: 01 Dec 2013 Location: Wokingham Posts: 103 ![]() ![]() ![]() |
OK, So does anyone know the part number for the modified filter, so I can order one in and fit it as preventive maintenance please, Or will Dan supply me 2 please? |
GraemeC Member Since: 01 Jul 2012 Location: Chester Posts: 836 ![]() ![]() ![]() |
Thanks Gaz, ordered from Amazon and replaced this morning - old filter wasn't too bad but air flows through the new filter a bit easier
tassietd6 Member Since: 16 Nov 2014 Location: Tasmania Posts: 10 ![]() ![]() |
Hi Tassie
