Home > Maintenance & Mods (L322) > Range Rover L322 - Stuck in Extended or Off Road Height |
They seem to clog to the point where they are a plug very suddenly! |
16th Jan 2014 1:51pm |
19th Jan 2014 1:59pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16280 |
There is a modified part from LR (ask Dan) with a hole in it already... Been an issue for years We check and change them on major services if still fitted with the old type... Approx £7 from main dealer If I remember correctly...
19th Jan 2014 2:07pm |
And very easy to drill your existing one.... |
19th Jan 2014 2:12pm |
Why bother when you can fit an inexpensive new JLR approved part |
19th Jan 2014 2:16pm |
Because when it happens chances are you will not have the new JLR approved part. Drilling (or simply removing) takes a few minutes and your cured and can continue your journey (you may be in Outer Mongolia). By all means then order a spanking new JLR part
19th Jan 2014 2:19pm |
Ok Gary... Well done you |
19th Jan 2014 2:21pm |
If you make "rolling eye" comments on my threads please expect me to make common sense replies |
19th Jan 2014 2:24pm |
It's common sence for forum members to perform preventative maintenance and fit a revised inexpensive part before a breakdown situation in my eyes...
19th Jan 2014 2:33pm |
Sorry Craig I reminded poster of the simple drill fix in a friendly manner and YOU came in with rolling eyes? |
19th Jan 2014 2:36pm |
87RJD Member Since: 01 Dec 2013 Location: Wokingham Posts: 103 |
OK, So does anyone know the part number for the modified filter, so I can order one in and fit it as preventive maintenance please, Or will Dan supply me 2 please? |
19th Jan 2014 11:50pm |
GraemeC Member Since: 01 Jul 2012 Location: Chester Posts: 836 |
Thanks Gaz, ordered from Amazon and replaced this morning - old filter wasn't too bad but air flows through the new filter a bit easier
25th Jan 2014 1:40pm |
tassietd6 Member Since: 16 Nov 2014 Location: Tasmania Posts: 10 |
16th Nov 2014 1:08am |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6407 |
Hi Tassie
16th Nov 2014 2:29pm |
