Home > Group Buys > flip keys [New Order Oct 2014] |
Simes Member Since: 30 Aug 2011 Location: Hinckley Posts: 964 |
When you sync (any) key to the Range Rover, you have to do all the keys that you want to use - the syncing process deletes any previously synced keys.
31st Oct 2013 12:08pm |
Mustard Member Since: 25 Jun 2013 Location: North of South Posts: 299 |
*Update*
31st Oct 2013 12:26pm |
It does sound like a bad cut of the key - try it in the lock the other way round (180 degrees) and see if it works then - one of mine (I had two cut) was a bit sticky in one orientation but OK in the other - a bit of jiggling it in the lock got it to work OK - but I took it back to the cutter who ran the cutter over it again (remember to take the original key that does work OK with you) and it's fine now - probably a 0.001mm of burr somewhere on the cut that is stopping it from working.
31st Oct 2013 12:30pm |
AKIS, you have to sync all the keys you want to keep using. So it is a batch sync. If you leave one key out, it will be "unsynced" but will resync if you repeat the process with that particular key included. MY 2010 5.0 SC Galway green and sand interior!!
31st Oct 2013 1:06pm |
AKIS Member Since: 23 Apr 2009 Location: GREECE Posts: 186 |
Simes thanks for your clarification.Basis flip key synchronized after 30secs i have to resync the old key.Do i have to follow procedure from the very beginning,ie to turn ignition to I then to 0 and so on or just to press locking/unlocking,as stated of old key. |
31st Oct 2013 1:10pm |
DTaylor Member Since: 15 May 2013 Location: Manchester Posts: 163 |
Mustard is this the old style or new style key? I spoke to daveo and had the same problem. It was because it had 2 transponder chips. I didnt know it had one in when daveo sent it to me. So just check theres only yours in there as if there is 2 it wont turn the car over |
Set the car into pairing mode (ignition on and off and key out in 5 seconds - then sync key 1 - as soon as that key is synced, don't tough the ignition or anything, and sync the next key(s) until you've done all the keys you need to use. The instructions are in more detail further up this thread somewhere. Have you got the key turning in the lock yet? |
31st Oct 2013 2:19pm |
Ebajema thanks yr reply.
31st Oct 2013 2:28pm |
Sorry +AKIS - it wasn't you who couldn't get it to turn!
31st Oct 2013 2:31pm |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
Hi, I think most of you have got your keys working with ref to the bad key cutting job.
31st Oct 2013 5:30pm |
No just the 1 transponder but the actual key wont turn in the ignition barrel
Not yet as Ive got to get back to the key cutter and have him check the keys over, no matter what I try the key will not turn the ignition and Im out of options with it Ill be well if hes the key cutting up |
31st Oct 2013 11:16pm |
mustard, do you here the click as you put the key in V8 facelift Range Rover Autobiography 22" wheels.
31st Oct 2013 11:21pm |
with no transponder no clicking,
31st Oct 2013 11:29pm |
then its down to the cutting, V8 facelift Range Rover Autobiography 22" wheels.
31st Oct 2013 11:34pm |
