Home > Group Buys > flip keys [New Order Oct 2014]
Sign Up
(28)
(58)
(18)
User Registered Confirmed
Stephen.12531st Aug 2013 1:19pm
andyleeds6th Sep 2013 5:53pm
DTaylor21st Sep 2013 4:12pm
Elduke7th Oct 2013 9:31pm
daveo26th Feb 2014 11:08pm
gregh14th May 2014 8:33pm
gezzer152013th Aug 2014 2:44pm
Bunchy1001st Nov 2014 2:08am
dhallworth16th Nov 2014 11:26pm
tony6623rd Jan 2015 10:53pm
47p217th Feb 2015 7:01am
Stomer Drl9th Apr 2015 7:19am
hex8th Jun 2015 8:38pm
J9022nd Jul 2015 7:57pm
socialrover17th Oct 2015 12:48pmsocialrover is confirmed
dolph3418th Oct 2015 8:21pmdolph34 is confirmed
freeforme7728th Dec 2015 5:44pmfreeforme77 is confirmed
prayer16312th Feb 2016 12:22pmprayer163 is confirmed
TrumptonDave15th Jun 2016 10:30amTrumptonDave is confirmed
kz355130th Aug 2016 8:20pm
Krams15th Oct 2016 5:58pm
tcmnorcal6th Oct 2017 1:21pm
seaneb7th Nov 2017 10:19pm
Quiff6th Aug 2020 5:57pm
abalanos5th Feb 2021 4:50pm
Steaky18th Feb 2022 10:28am
its me5th Aug 2022 12:20pm
yomchi8613th Nov 2023 9:00pm
Baldrick563528th Aug 2013 9:22pm
Mustard28th Aug 2013 10:27pm
MrP29th Aug 2013 3:21pm
willowzn30th Aug 2013 9:10pm
andy18030th Aug 2013 10:09pm
flipflop1st Sep 2013 11:36pm
RichTD66th Sep 2013 9:17pm
Tallsaj9th Sep 2013 9:08pm
glennhoward11th Sep 2013 6:58pm
kruger200218th Sep 2013 10:45pm
Simes19th Sep 2013 5:52pm
geordiefella8th Dec 2013 2:30pm
redshovel3rd Jan 2014 8:43pm
jak4807th Jan 2014 6:07pm
dazt_8515th Jan 2014 10:24am
cliffy8th Feb 2014 6:44pm
Winchester1018th Feb 2014 8:50pm
rej12th Feb 2014 7:47pm
mick-ne24th Feb 2014 10:22pm
steviebabes25th Feb 2014 9:19am
rads26th Feb 2014 1:47pm
dba1128th Feb 2014 6:37pm
RRIII5th Apr 2014 6:40am
Needle12th Jul 2014 7:48pm
jj29081st Sep 2014 7:44am
docjones23rd Sep 2014 9:31pm
Smegordead29th Sep 2014 6:55pm
Turnover30th Sep 2014 12:43pm
Roofer1st Nov 2014 6:43am
comports2nd Nov 2014 5:37pm
mgbgtv826th Nov 2014 7:46pm
Jaipo7th Dec 2014 7:40pm
chex3rd May 2015 10:26pm
shinchan2nd Jun 2015 4:05pm
Boydonegood6th Jun 2015 6:42am
DannyH8th Jun 2015 10:52am
Billydun3416th Aug 2015 9:20pm
zetjester14th Nov 2015 5:40pm
Mike.Boro18th Nov 2015 4:20am
davethomas8329th Dec 2015 2:24pmdavethomas83 is confirmed
MCM665th Jan 2016 10:37pm
Ohwhatalad7th Jan 2016 8:46pm
454awg27th Jan 2016 7:31am
Ollie_24726th Feb 2016 4:07pm
Big Tings11th Jun 2016 6:09pm
CY8816th Jun 2016 12:41pm
Wylie6619th Jun 2016 8:19pm
MatsonTAS20th Jun 2016 6:57pm
Donnor26th Jun 2016 5:28pmDonnor is confirmed
ErwinS19th Feb 2017 8:12pm
Rewmer24th Feb 2017 3:57pm
alfapat25th May 2017 6:09am
nebc10028th May 2017 7:54pm
L322 Newbie27th Jul 2017 6:18am
easylife10312th Oct 2017 7:16pm
biggirly119th Sep 2018 10:23pm
haaris19th May 2020 4:08pm
Mane_Ugle11th Oct 2021 9:52pm
ebajema28th Aug 2013 6:22pm
markpr28th Aug 2013 7:16pm
cstowe212028th Aug 2013 9:37pm
AKIS29th Aug 2013 1:24pm
jwclements12nd Sep 2013 2:36pm
duck109816th Sep 2013 10:15pm
Scottrx7tt16th Nov 2013 3:10pmScottrx7tt is confirmed
RangeK1D5th Mar 2014 11:20amRangeK1D is confirmed
christoforos7th Apr 2014 1:34amchristoforos is confirmed
markskyline20th Oct 2014 10:51ammarkskyline is confirmed
Kaj28th Feb 2015 5:36pmKaj is confirmed
Ian c229th Dec 2015 8:58pmIan c2 is confirmed
rar11016th Apr 2016 11:23pmrar110 is confirmed
beaudog1111th Jun 2016 8:34pmbeaudog11 is confirmed
csufy27th Feb 2017 3:40pm
Lukie24th Jun 2017 10:18am
jonasserra12th Jul 2017 11:07am
muddycharles3rd May 2024 3:52pm
Page 9 of 36 <123 ... 8910 ... 343536>
AKIS
2004 Range Rover Vogue Td6 Cairns Blue
Hi Dave and new key with me.Just a question so to be on safe side.Right now i have two old type keys and i will replace the one of them with the new flip key.The other one i will keep it as spare.
So as soon as i will sync the new flip key i must also resync the old one that i will keep as spare so to be both functional or with old/spare key i have to do nothing.
Post #219953 31st Oct 2013 11:52am
Simes
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
When you sync (any) key to the Range Rover, you have to do all the keys that you want to use - the syncing process deletes any previously synced keys.
So, you have to do them all at the same time.
Post #219958 31st Oct 2013 12:08pm
Mustard
*Update*
I have managed to get the key to sync in the end, the 5 second key turn from 0 to 1 back to 0 helped a lot, success. So after syncing I transferred the chip accross and popped it in the ignition, made all the right clicking sounds but didnt turn the dam ignition LoL. It does turn the lock in the drivers door but alas not the ignition, does this sound like a bad cut of the key ?
Post #219961 31st Oct 2013 12:26pm
Simes
It does sound like a bad cut of the key - try it in the lock the other way round (180 degrees) and see if it works then - one of mine (I had two cut) was a bit sticky in one orientation but OK in the other - a bit of jiggling it in the lock got it to work OK - but I took it back to the cutter who ran the cutter over it again (remember to take the original key that does work OK with you) and it's fine now - probably a 0.001mm of burr somewhere on the cut that is stopping it from working.
I'd try it the other way round, and with a bit of jiggling just to see if it does work - then if not, back to the cutter.
Post #219962 31st Oct 2013 12:30pm
ebajema
AKIS, you have to sync all the keys you want to keep using. So it is a batch sync. If you leave one key out, it will be "unsynced" but will resync if you repeat the process with that particular key included. MY 2010 5.0 SC Galway green and sand interior!!
Post #219974 31st Oct 2013 1:06pm
AKIS
Simes thanks for your clarification.Basis flip key synchronized after 30secs i have to resync the old key.Do i have to follow procedure from the very beginning,ie to turn ignition to I then to 0 and so on or just to press locking/unlocking,as stated of old key.
Post #219977 31st Oct 2013 1:10pm
DTaylor
United Kingdom 2005 Range Rover Vogue SE 4.4 V8 Chawton White
Mustard is this the old style or new style key? I spoke to daveo and had the same problem. It was because it had 2 transponder chips. I didnt know it had one in when daveo sent it to me. So just check theres only yours in there as if there is 2 it wont turn the car over
Post #219979 31st Oct 2013 1:10pm
Simes
Set the car into pairing mode (ignition on and off and key out in 5 seconds - then sync key 1 - as soon as that key is synced, don't tough the ignition or anything, and sync the next key(s) until you've done all the keys you need to use.
The instructions are in more detail further up this thread somewhere.
Have you got the key turning in the lock yet?
Post #220001 31st Oct 2013 2:19pm
AKIS
Ebajema thanks yr reply.
Simes i rcvd flip key today so i have done nothing other than asking you guys so to make sure if something will go wrong with flip key to have a spare key to run car.
Post #220004 31st Oct 2013 2:28pm
Simes
Sorry +AKIS - it wasn't you who couldn't get it to turn!
+Mustard - have you got your one working now? I must have dropped lucky as I got the keys cut at lunchtime at work, then sat at my desk and swapped the transponders over (takes all of 5 minutes to do both keys) and that was that! Job done.
Post #220005 31st Oct 2013 2:31pm
daveo
Hi, I think most of you have got your keys working Thumbs Up with ref to the bad key cutting job.
check the tips of the keys and compare the tip length, if the blank is in further than the original then the cutting will start further up the blade, it can be a 1mm and while in the door there is not a problem it will not work,
Key blanks are hard to get hold off so try a little tinkering.
Be sure to check you get the click from the ignition as you put the key in, make chip sure you only have the one chip in the key, I did over look a couple Embarassed V8 facelift Range Rover Autobiography 22" wheels.
Post #220033 31st Oct 2013 5:30pm
Mustard
No just the 1 transponder but the actual key wont turn in the ignition barrel
Not yet as Ive got to get back to the key cutter and have him check the keys over, no matter what I try the key will not turn the ignition and Im out of options with it Laughing
Ill be well Censored if hes Censored the key cutting up Thud
Post #220089 31st Oct 2013 11:16pm
daveo
mustard, do you here the click as you put the key in V8 facelift Range Rover Autobiography 22" wheels.
Post #220091 31st Oct 2013 11:21pm
Mustard
with no transponder no clicking,
with transponder transplanted into it I hear all the same clicking my normal key makes happen
Post #220094 31st Oct 2013 11:29pm
daveo
then its down to the cutting, Sad V8 facelift Range Rover Autobiography 22" wheels.
Post #220095 31st Oct 2013 11:34pm
