![]() | Home > Group Buys > flip keys [New Order Oct 2014] |
Mustard Member Since: 25 Jun 2013 Location: North of South Posts: 299 ![]() ![]() |
Im also interested in having the newer style flip key, 54 plate td6 vogue.
TtheArab Member Since: 26 Apr 2013 Location: Dunblane, Scotland Posts: 89 ![]() ![]() |
Put me down for one. 2003 HSE so should not be any issue. |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 ![]() ![]() ![]() |
hi martin,how do i set that up V8 facelift Range Rover Autobiography 22" wheels. 1976 Harley Davidson Iron Head Sportster |
pm me your address and i will post it on to you, give it a go ![]() 1976 Harley Davidson Iron Head Sportster |
i have arranged for the spare key to go out for some one to test, i can forward it on to you after if you like and you can test it on your car.. V8 facelift Range Rover Autobiography 22" wheels. 1976 Harley Davidson Iron Head Sportster |
if you want to keep the key you have and want a complete new key then yes you will need a new transponder chip, ews will need to be read,if you are happy with just the one key then just transfer the chip into the new key, job done you need to find a timpsons with a colt machine, will cut what they call lazer cuttin even know there is no lazer V8 facelift Range Rover Autobiography 22" wheels. 1976 Harley Davidson Iron Head Sportster |
Hi Dave, if it works on the test car just order me one. Sending it back and forth will take a lot of time and cost more probably ;P MY 2010 5.0 SC Galway green and sand interior!! Have the Faultmate MSV2 Extreme to be tinkering with the settings etc. !! |
jwclements1 Member Since: 27 Aug 2013 Location: Virginia Posts: 5 ![]() ![]() ![]() |
I'll take one new key. have a 2003 HSE, can't initiate a PM, joined for this. send me one if you need paypal info |
DTaylor Member Since: 15 May 2013 Location: Manchester Posts: 163 ![]() ![]() ![]() |
So is it possible they wont work on a touchscreen 2004/5?
i take it you are in the usa, are your keys 433 or 315 mhz. V8 facelift Range Rover Autobiography 22" wheels. 1976 Harley Davidson Iron Head Sportster |
My car is USA (NAS spec) as well by the way so the 315 MHz if I'm correct |
look at the link, page 2 and you will see both types http://www.fullfatrr.com/forum/topic18624.html V8 facelift Range Rover Autobiography 22" wheels. 1976 Harley Davidson Iron Head Sportster |
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1522 ![]() ![]() |
Cheers Daveo PM sent.
oh gotcha, it is 315. so I can't do anything? |
