Home > Maintenance & Mods (L322) > Bleed Screw Fix? - PTFE Teflon Tape (Coolant Loss)
Page 1 of 3 123>
pld118
The issues in this post are covered in another, longer, recent thread http://www.fullfatrr.com/forum/topic21351.html but the purpose of this post is to focus on a simple solution relevant to some cases of coolant loss:
Having spent the best part of a week trying to stabilise coolant loss coming from the black cross head bleed screw on the expansion tank (Image 1) and having seen a previous post which commented that a defective bleed screw can result in there being a need for a replacement expansion tank http://www.fullfatrr.com/forum/topic9849.h...leed+screw , despite the fact that ours is all under warranty, a simple, cost effective and efficient remedy does exist in the form of:
Plumbers PTFE Teflon tape (Image 3)
In our case the expansion tank and the bleed screw (Image 2) are as new. However, it appears that there was no actual rubber o-ring on the bleed screw. The bleed screw had a tendency to shift & need constant adjustment to tighten (close) because of the hot and cold expansion and contraction of the plastic expansion tank through normal use of the car.
The solution in our case was to carefully wrap a reasonable amount of PTFE tape around the thread of the bleed screw, taking care not to then overtighten the bleed screw so as to avoid damage to the bleed screw and/ or the screw hole that sits on the top of the expansion tank.
3 days on since using the PTFE tape and the problem is completely solved. Thumbs Up
Image 1:
Image 2:
Image 3:
Post #217642 20th Oct 2013 7:14am
greasemonkey1
United Kingdom 2005 Range Rover Vogue Td6 Java Black
hi
just thought id mention something relating to the coolant loss issue,,not going off the subject but last week my vogue went into the dealership for a compressor leak test of which it failed because of the seal kit issue that i started a post about on here but however whilst there they looked under the bonnet and drained my antifreeze and replaced it ,because they said it was the WRONG color,it should be BLUE and not PINK,as the pink one cannot match the high end scale of the temperature the l322 run at,,they done that ,flush the system and bled it free of charge for me, as i had to wait around before i got seen,just thought id mention it as in your picture the coolant in the expansion tank is pink,i know you have another model to the l322 but maybe its something you might need to look into.. i was totally unaware of the pink or blue issue but they pointed it out to me and done it FREE of charge so there was nothing in it for them to gain,don't know if this varies between dealership but i left a happy bunny.. Very Happy steve
Post #217644 20th Oct 2013 8:35am
pld118
Hi Steve, thanks for the info. Input from learned professionals and enthusiasts on this forum is overwhelmingly that the colour should be pink/ orange; and the main dealer I use (Stratstone) also use this colour of coolant. The picture of the organic coolant on the linked post is of a bottle that Stratstone gave me. For our SC, the pictured coolant is correct.
Cheers Thumbs Up
Post #217648 20th Oct 2013 9:07am
greasemonkey1 wrote:
hi
Steve, I do hope you have got confused with your colours... Pink is the colour for all L322 RR's fact... If someone has removed yours and replaced it with blue then you need to march straight back down there and have them reverse it as Blue will eat away seals, gaskets etc Shocked
Google it Thumbs Up
Post #217664 20th Oct 2013 10:21am
^^^+1 Recommended coolant for all L322's is 50% mix Havoline XLC and water which is orange.
You definitely do not want a Blue Coolant mix.
Post #217669 20th Oct 2013 10:26am
greasemonkey1
hi
Google it Thumbs Up
will ring few range rover dealership around the country tomorrow asking them what colour it should be as iv'e googled it and some says blue some says pink... Confused but if the majority says pink then i will get west london landrover dealership to change it back to what it was,,wonder why they would tell me other wise and even change it for me free of charge...will get back to you on this alarming issue...
thanks for your feedback...steve
Post #217731 20th Oct 2013 5:26pm
ORANGE/PINK for 2005+ JAG Cars but BMW based cars where BLUE originally I think!!!
NEVER seen blue in the white see through coolant tanks though.
Post #217732 20th Oct 2013 5:29pm
greasemonkey1
just to clarify things,,when i bought my one previous owner 2005 l322 the color of the coolant was pink....west london land rover dealership name " lookers" changed to blue last week to which it still is till further investigation... Confused
Post #217734 20th Oct 2013 5:31pm
greasemonkey1
my coolant tank is black and not see through,,i was told that the coolant should be blue and not pink due to the working temperature of the l322 model and had it changed by dealership,i didn't request it...
Post #217736 20th Oct 2013 5:35pm
^ Yes as I said 2005+ White Tank is PINK and 2002-2005 BMW Black Tank is BLUE.
Post #217738 20th Oct 2013 5:38pm
greasemonkey1
Laughing i'm confused now...so am i right to believe that the coolant which was replaced by my local dealership in my l322 2005 vogue which is now blue is the correct coolant ... ??? i understand that over time my vogue has got older and at this time of its life being older it should be changed to blue from pink...sorry for hijacking your thread pld118,looks like this is a confusing issue..
Post #217744 20th Oct 2013 5:58pm
TugRR
Just got a top up litre for mine from MD.
2006 4.4 V8 Jag engined car = pink - same as S/C.
Could it be the blue is for Td6 and BMW 4.4 V8 engine cars ?
Thumbs Up Where do you go after one of these . . . ?
Post #217746 20th Oct 2013 6:09pm
lubricant seems to be the same according to this in the wiki,
http://www.fullfatrr.com/wiki/Recommended_Lubricants ... - .- -.
Post #217747 20th Oct 2013 6:14pm
My post was quite clear Surprised
WHITE TANK - PINK COOLANT ONLY
BLACK TANK - BLUE COOLANT (Could have been replaced with Pink)
This is based on experience only I am not a LR Service Agent Thumbs Up
Post #217749 20th Oct 2013 6:28pm
PaulB
2017 Range Rover Autobiography SDV8 Loire Blue
I think the major issue is if you mix different colours.
Sludge forms and causes overheating.
Post #217760 20th Oct 2013 7:58pm
Page 1 of 3 123>
