![]() | Home > Maintenance & Mods (L322) > Bleed Screw Fix? - PTFE Teflon Tape (Coolant Loss) |
The issues in this post are covered in another, longer, recent thread http://www.fullfatrr.com/forum/topic21351.html but the purpose of this post is to focus on a simple solution relevant to some cases of coolant loss:
Image 2:
Image 3:
Hi Steve, thanks for the info. Input from learned professionals and enthusiasts on this forum is overwhelmingly that the colour should be pink/ orange; and the main dealer I use (Stratstone) also use this colour of coolant. The picture of the organic coolant on the linked post is of a bottle that Stratstone gave me. For our SC, the pictured coolant is correct.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16334 ![]() ![]() ![]() |
Steve, I do hope you have got confused with your colours... Pink is the colour for all L322 RR's fact... If someone has removed yours and replaced it with blue then you need to march straight back down there and have them reverse it as Blue will eat away seals, gaskets etc ![]() Google it ![]() |
^^^+1 Recommended coolant for all L322's is 50% mix Havoline XLC and water which is orange.
greasemonkey1 Member Since: 22 Sep 2013 Location: london Posts: 157 ![]() ![]() ![]() |
will ring few range rover dealership around the country tomorrow asking them what colour it should be as iv'e googled it and some says blue some says pink... ![]() thanks for your feedback...steve |
ORANGE/PINK for 2005+ JAG Cars but BMW based cars where BLUE originally I think!!!
just to clarify things,,when i bought my one previous owner 2005 l322 the color of the coolant was pink....west london land rover dealership name " lookers" changed to blue last week to which it still is till further investigation... |
my coolant tank is black and not see through,,i was told that the coolant should be blue and not pink due to the working temperature of the l322 model and had it changed by dealership,i didn't request it... |
^ Yes as I said 2005+ White Tank is PINK and 2002-2005 BMW Black Tank is BLUE. |
TugRR Member Since: 11 Jan 2011 Location: Bakewell Posts: 1200 ![]() ![]() |
Just got a top up litre for mine from MD.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35610 ![]() ![]() |
lubricant seems to be the same according to this in the wiki,
My post was quite clear ![]() WHITE TANK - PINK COOLANT ONLY BLACK TANK - BLUE COOLANT (Could have been replaced with Pink) This is based on experience only I am not a LR Service Agent ![]() |
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 ![]() ![]() |
I think the major issue is if you mix different colours.
