![]() | Home > Maintenance & Mods (L322) > Bleed Screw Fix? - PTFE Teflon Tape (Coolant Loss) |
Bellini Member Since: 11 Jan 2012 Location: Berkshire Posts: 2261 ![]() ![]() ![]() |
Sorry Ryan, but there's only one thing that'll save you now. It's the Ghostbusters song...
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35629 ![]() ![]() |
see, i told you you had a screw loose.. |
Yes Stan but you've not told the forum why!
As the tank and engine were cooled down, I removed the expansion tank fill cap. Still, the pink coolant remained as pictured above within the 'upper chambers' of the tank. So - with tank fill cap still off - I also then removed the bleed screw and the pink coolant instantly drained away back down into the tank and settled properly as pictured below, showing that in fact, I've got slightly more coolant in the tank than the range fill parameters require. However, I don't think it's such an excessive amount as to be unduly concerned; and whilst I monitor the performance of the bleed screw over the coming days, that excess might actually serve me well:
I then, for now preferring PTFE Teflon plumbers tape to rubber o-rings, carefully wrapped some fresh PTFE tape around the bleed screw thread before re-inserting the bleed screw in the tank and closing it, careful not to overtighten. Took the car for a spirited driving in sport mode up and down the motorway, got it at full operating temperature and the needle hasn't moved from approx 12 o'clock/ perfectly normal temperature. There are no warning messages and thus far, no leaks from the bleed screw or anywhere else! Simple to you perhaps but a challenge to me ![]() Fingers crossed ![]() |
sweaty1 Member Since: 15 Mar 2016 Location: kent Posts: 5 ![]() ![]() ![]() |
I know the sis an old post but if your bleed screw has an `O ring then take it off and refit it reversed . They compress and taper over time . If not then new one or PTFE tape . O ring better fix though 2006 Thailand G4 Event Press Vehicle and still working hard |
Or use gasket sealant or similar, that worked for me |
