![]() | Home > Maintenance & Mods (L322) > Bleed Screw Fix? - PTFE Teflon Tape (Coolant Loss) |
So this morning, into a cold engine and cold coolant tank, I topped up the coolant within the range fill markers. It took about 400ml of 50/50 water coolant mix (Picture 1).
It could be a crack in the tank/hose that opens up when the tank cools. Other option (and that happened to me) is that your engine oil / coolant heat exchanger has ruptured !!!
MachineHead Member Since: 20 Apr 2014 Location: The hoose Posts: 310 ![]() ![]() ![]() |
I'm not 100% clear on what you're saying here, do you mean I can't have green with a lemon twist? ![]() |
The green coolant is suitable for aluminium engines, however, the orange is supposed to be bio-degradable and the green one is not. Or at least that is one explanation I heard.
Thanks Eugene,
Ah, that makes more sense and sounds less sinister !!! Hope that is the case.
Cheers Eugene... Hope I'm right!
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1522 ![]() ![]() |
As above; if the system is not very well flushed. the mix of coolant will create a brown sludge that clogs galleys in the water jacket and will give major headaches! |
Thanks happym... Okay. Assuming I've got more than a [bleed] screw loose with this car |
If it's clean I'd say |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
coolant colour?
Well, it seemed (although the jury was still out) to have stabilised from the point of not depositing pink coolant all over the garage floor overnight. Was hopefulnmost of the ongoing deposits up to midday yesterday were remnants of coolant fluid that had poured out of the bleed screw hole and had dripped down the external of pipes, down the engine bay and escaped out via various under tray holes.
