Home > Technical (L322) > [Solved -> FSR]Battery Drain Consumption identification |
Ibartsimp Member Since: 24 Dec 2012 Location: Bordeaux, France Posts: 197 |
what do you mean by more positively? I now use crocodile clips (jump start cables in fact).
29th Jan 2013 6:16pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3972 |
No that is ok, no need to repeat.
29th Jan 2013 6:24pm |
Ok, so to sum up:
29th Jan 2013 6:41pm |
You can have they battery tested at a garage using a device that connects the +ve and -ve terminals together through a high resistance load.
29th Jan 2013 6:48pm |
I'll have the battery tested tomorrow (I have my tyres changed) but if it's ok, this means that I have an internittent battery drain wich is worse I guess.
29th Jan 2013 8:20pm |
10mA drain means you don't have a problem, FSR or anything else.
29th Jan 2013 9:09pm |
Hum, so, I have to
29th Jan 2013 9:24pm |
No, engine off, disconnect 1 from 2 as below and connect ammeter to 1 and 2.
29th Jan 2013 9:34pm |
Oh easy job ! I'll (re)do that tomorrow indeed. 2008 TDV8 VOGUE - Buckingham Blue on Sand |
29th Jan 2013 9:48pm |
Hi guys, I've redone it today and it still reads 0.01...
30th Jan 2013 4:44pm |
I am soooooooooooo fed up with this issue: won't start this morning when I wanted to bring the car to have the battery (re) tested.
31st Jan 2013 8:30am |
You just have the worst kind of car problem you can imagine, the intermittent fault. I hope that whatever is the problem fails completely soon, so you know exactly what to replace.
31st Jan 2013 8:39am |
Indeed, very annoying... After previous tests (see above in the thread), it seemed to me I had eliminated the FSR & alternator possibilities, no? 2008 TDV8 VOGUE - Buckingham Blue on Sand |
31st Jan 2013 8:44am |
Not if it is an intermittent fault, it could have been fine while testing and then act up again when you leave the car parked. MY 2010 5.0 SC Galway green and sand interior!!
31st Jan 2013 9:17am |
