Home > Maintenance & Mods (L322) > Rear Wheel Arch Rust Repair ?
Page 1 of 4 1234>
mjdronfield
Has anyone got any thoughts on how to fix the rust that appears to be coming through on the rear wheel arch lips ?
I've just been up to the local Land Rover approved repairers in Chesterfield, who say that it'll really need a new complete panel at �2500 ish. Someone on here did this if I remember right.
I appreciate that it can't be guaranteed it won't come back through, but can you not sand back to metal and start again with primers, undercoats, stone chip etc ?
Or, should we be looking for more of a "vehicle bodywork restorer", who can cut the lip out and replace with new metal ?
Like most of us I'd imagine - I don't really want it coming back through, but don't want it to cost a fortune..........
(nothing new there then !!)
many thanks
Mark 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #101575 13th Jan 2012 4:09pm
NKSC
United Kingdom 2005 Range Rover Vogue SE Supercharged Zambezi Silver
I know RRUK did his himself not so long ago, and posted on here about it. Can't find the post though!
Post #101577 13th Jan 2012 4:24pm
mjdronfield
I did a search, and there were a few posts from people who had the issue, and what they were doing, but done said what exactly they'd done, and whether it had actually worked or not.
all the best
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #101579 13th Jan 2012 4:28pm
NKSC
http://www.fullfatrr.com/forum/topic7192-30.html
A few ideas here??
Post #101580 13th Jan 2012 4:32pm
A1GSS
Or here:
www.fullfatrr.com/forum/topic7192.html
Look at second page. Graham
____
Gone: 10MY L320 RR Sport HSE, Ipanema Sand
Gone: 20MY Jaguar iPace HSE, Silicon Silver
Gone: 17MY RR Evoque SE Tech, Loire Blue
Gone: 08MY Discovery 3 XS, Stornoway Grey
Gone: 07MY FFRR TDV8 Vogue, Stornoway Grey
Post #101583 13th Jan 2012 4:38pm
After treating and painting the lip edge you can fit a length of black plastic door edge trim, the type people use to protect door edgs from knocks, over the lip to protect it against further chipping etc. Butts up well against the rubber trim on the door edge when closed and looks surprisingly professional.
Post #101585 13th Jan 2012 4:47pm
nicedayforit wrote:
......you can fit a length of black plastic door edge trim, .......
Great for catching dirt and water, does not allow the lip to dry out properly.
Better to treat with a Waxoxy type rust preventer and wash the lip with the hosepipe every now and then
Post #101601 13th Jan 2012 5:26pm
Not at all, I applied a layer of grease to both sides of the lip before fitting the strip.
I have every confidence the lip is now well protected. I will re-apply the grease yearly.
Post #101613 13th Jan 2012 6:08pm
Yep, did mine myself, and I am no expert at spray painting etc.
I rubbed down the rust, painted it with Hammerite satin black to cure/kill/stop the rust, then sprayed over with genuine colour spray paint from Dan @ Duckworths, gave it 2 coats, then 2 coats of clear lacquer afterwards.
Did it in between other outdoor jobs one weekend, all looks fine now, but mine was only surface rust, not corroded metal flaking away or anything. Discovery 4 HSE
Post #101615 13th Jan 2012 6:19pm
mjdronfield
Thanks Gents.
I spoke to the garage where I got the car, knowing they had some scuffs painted in. They can't remember if wheel arches had to be done. From memory, they thought it was only minor bits they had done, but are double checking for me on Monday. Obviously if they did pay for the arches to be fixed, it will have to be done again.
Failing that, think I'll find a bodyshop to treat it properly, and see how long it lasts.
Will keep you posted.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #101694 14th Jan 2012 3:43pm
klf400
i see where your coming from , this edge is unprotected and with greaseing/waxing etc should prolong its life .
the l322 arch liner is crap compared to that of the p38 .
the p38 arch liner can be removed easy and is held in with plastic clips and the liner lips over the metal arch and is a good seal .
but the l322 lips behind the metal arch which allow dirt/mud to trap inbetween the metal arch and liner also the fixings for the liner are metal and rust away and break of
not a good design or improvement but a step backwards 1990 3.5 v8 defender
2000 4.6 v8 30th anniversary prins lpg
2004 4.4 v8 vogue prins lpg
2011 4.4 TDV8 Vogue
faultmate extreme
rsw allcoms
Autel 906BT
Gap iiD tool
Post #101695 14th Jan 2012 4:02pm
Diver Bryn
United Kingdom 2005 Range Rover Vogue Td6 Tonga Green
L/R replaced my rear right side wing under the 5 year anti corrosion warranty. Still had rust coming through on inner exposed steel lip from stone chips. Pity L/R did not fit rubber arch protectors. I have painted this area with hemerarite rubber wax oil to protect against stone chips this is an easy fix. Diver Bryn
Previous Transport:
Honda CB250n
Toyota Starlet
Renault Fuego 2 ltr TX
Fuego Turbo
BMW 528i
Escort RS Turbo
Capri 2.0 L Ghia
Kawasaki GT750 P4
Mini Metro
Ford XR2
Volvo 740 TDi Estate
Mondeo Tdi
Volvo V70 Tdi
Mercedes E300 TDI
Mercedes E320 Cdi
Mercedes S320 Cdi
Land Rover Discovery 3 TDV6
Mini Cooper Diesel
Mercedes Vito Van 111
Range Rover TD6
VW Golf 2ltr GTD 2015 Year
2016 Audi Q7 Sline 3ltr 272Bhp
Post #103020 22nd Jan 2012 9:25pm
mjdronfield
Well, I've just dropped it off at the bodyshop, as the garage I bought it from have offered to pay for the work.
They are stonechipping the arches, amongst other things.
Should be ready Wednesday morning...........
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #103158 23rd Jan 2012 3:59pm
mjdronfield
Well I picked the car up yesterday, and I'm very happy with the results. The bodyshop said the rust was only on the surface. They have gone back to metal, treated it, stone chipped it and painted over it.
We shall see how long it lasts.
Plenty of dirt and dust left inside the car though, so for the 3rd time in less than a week, its having another thorough interior clean. Must be something about garages that work for car dealers not having to worry about it, as the car would normally be valeted by someone else after.........
Many thanks
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #103604 26th Jan 2012 12:10pm
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
Thanks for the update-
FWIW Bilt Hamber make some really good rust treatment stuff including a great anerobic gel.
Post #103617 26th Jan 2012 12:32pm
Page 1 of 4 1234>
