Home > Maintenance & Mods (L322) > Rear Wheel Arch Rust Repair ?
Page 3 of 4 <1234>
mjdronfield
They just push on. No screws or anything. Cutting to length was the "hardest" bit, I did a test fit, without Vaseline on one side, and then cut the other side to match.
I filled the groove with Vaseline to stop water ingress, but that pretty much all comes out when you push on.
Looks much better in my opinion.......
Mark 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #115442 29th Mar 2012 3:54pm
Flashman
My 2004 had them on already when I bought my car so maybe this was done by some dealers as part of general servicing. Tom
Current Drive
Previous Drives
Post #131953 19th Jul 2012 10:10am
mjdronfield
I wish someone had put them on mine a few years ago...........
.........or even from new..........LAND ROVER !! 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #131962 19th Jul 2012 10:29am
highfellzippy
United Kingdom 2015 Range Rover Autobiography SDV6 Montalcino Red
BEST FIX
clean it off paint it with hammerite or stone chip ect
then fit the front rubber wing arch rubbers from a 05 RRS i even wax oiled mine before fitting rubber strip
looks really good and no rust wing rubbers about £4 each from dealers
Post #132042 19th Jul 2012 7:36pm
STEVE57
England 2007 Range Rover Supercharged 4.2 SC V8 Cairns Blue
Re: BEST FIX
hi
anyone have part number for the wing arch rubbers????
thanks 2007 supercharged ,Cairns Blue with Navy & Parchment Interior
Post #132052 19th Jul 2012 8:37pm
Mjd lists them earlier in the thread. And there is a pic of the label also.
Dead cheap and easy to fit. Thumbs Up There is nothing that can't be fixed with a hammeršŸ˜œšŸ˜œ
Post #132065 19th Jul 2012 9:26pm
STEVE57
hi
thanks got the part numbers 2007 supercharged ,Cairns Blue with Navy & Parchment Interior
Post #132077 19th Jul 2012 10:17pm
DaveK
United Kingdom 2013 Range Rover Vogue TDV6 Corris Grey
Just tidying up some bubbling at the moment. I put edge protectors on when I got it but this bubbling is more towards the inside of the rear door aperture and seems to be where the door curved weather strip comes in to contact with the body at the bottom of the opening. Could it be rubbing ?
Post #478880 19th May 2018 12:04pm
GGDR
people put the strip on with a generous dollop of grease or other. I think the trick is to renew the grease etc once a year.
. Cheers, Greg
Post #478884 19th May 2018 12:37pm
Location: my House, unless Iā€™m not at home, in which case Iā€™m somewhere else.
Since it was such a fantastic day up here in Godā€™s own country and knowing my rear arches needed some attention, I picked up the wheel arch strips a couple of weeks back, so today I though Iā€™d make a start on getting rid of the rust.
Just one thing that puzzled me is that I donā€™t see any reference to anyone removing the rear wheel arch liner? I reckon you would need to, to get into the back of the wheel arch?
Is this the case, or do you just do all the ā€œtreatmentā€ from the front? Got - 2017 SDV8 Autobiography in Loire Blue
Post #479543 28th May 2018 5:42pm
Boxbrownie
United Kingdom 2008 Range Rover Vogue SE TDV8 Java Black
I checked my recently acquired (last week) and it already has them fitted, an ā€˜07 VSE and always main dealer serviced so I assume it had been fitted if not from new but by the dealer at some time. David
Please let me know if my comments upset you, I may wish to upset you again.
Post #479557 28th May 2018 8:08pm
MR GLOVER
United Kingdom 2005 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
I got mine done a couple of years ago took bumper off and wheel arch protectors proper job done but just got a few bubbles coming bk now Sad
Post #479558 28th May 2018 8:09pm
Paul thornton
I best order some quick before land rover realise what's going on and put the prices up by 3000%
Post #479592 29th May 2018 12:42pm
Rich_Allen
mjdronfield wrote:
Well I spent half an hour at the dealers this morning, sorting out these edge protectors.
I'll go and get a pic in a min - not fitted yet. Need to clean the arch and put some Vasalene in the protector and cut to length etc.
I bought 2 off VLR001623 for a grand total of ļæ½9.19 inc VAT.
They are 30 inch long, and were cheaper than the shorter ones !!
I figured I could cut to length.......
I examined a RRS when I was there, and it only had the protector on the bit of the arch under the rear quarter panel, not under the bit that the rear door overhangs - if that makes any sense.
Land Rover had loads in, different lengths etc, and as we are only getting some to fit, it doesn't have to be for a specific model.
I'll go and get a pic......
Here we go - not on, but I'm sure you get the idea....
Looks like an excellent find mate. Well happy........
Mark
These are the ones that are fitted standard to the front of a Freelander 2. Thumbs Up
Just ordered a pair for my freshly done rear arches... 2008 TDV8 Vogue SE
2002 TD6 Vogue
2002 Defender 90 TD5
2002 Range Rover P38 Autobiography
2002 Range Rover P38 Westminster
Just a sucker for big bills!!!
Post #487961 4th Sep 2018 11:06am
kooky_guy
United Kingdom 2010 Range Rover Vogue SE TDV8 Stornoway Grey
I can't help feeling uncomfortable about fitting a trim to the wheel arch lip - it just seems like a water trap to me.
Has anyone approached it from the direction of extending the arch liner somehow? 2010 4.4 TDV8 Vogue SE
Post #487972 4th Sep 2018 12:50pm
Page 3 of 4 <1234>
