Home > Maintenance & Mods (L405) > Oil change - which pump and which new oil and new filter?
Page 2 of 4 <1234>
knwatkins
How strange. I've been using mine for about 3 years, no problems at all and it sucks the entire oil capacity out in a few minutes. Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #695303 30th Jun 2024 4:58pm
JayGee
The model made 3 years ago maybe not the same as the one you can buy today? 2012 TDV8 Vogue (L322)
Post #695308 30th Jun 2024 6:52pm
D3Jon
I've found the cheap electric pumps to be utter tosh, no good for sucking 10L of oil up a 6mm (or so) diameter tube.
I bought a manual vacuum extractor from Ebay and it's been brilliant. Makes changing the oil and filter a simple and clean task.
This is the one I bought: https://www.ebay.co.uk/itm/223385433390
Only downside, is with just 9L capacity, you have to empty a bit out to extract the full amount in a 4.4 TDV8! Very Happy
Jon 1992 RR Classic 3.9 efi Vogue
2014 Disco 4 HSE
Both my fatties now gone...
Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus)
Post #695311 30th Jun 2024 7:58pm
JayGee
This looks like a slightly more robust unit with proper hose connectors.
https://www.ebay.co.uk/itm/335450064716
The extraction tube internal diameter is around 5/6mm so still can't see how the whole sump can be emptied by anything quickly 2012 TDV8 Vogue (L322)
Post #695319 1st Jul 2024 5:51am
caymanblack
I was looking at that one Jay also , look around as its available for £12. overfinch modified
Post #695343 1st Jul 2024 11:18am
JayGee
The stated flow rate will empty the sump in 20-30 mins according to the spec sheet and it will run for 30mins max so could be a bit marginal. This one may be better?
https://www.ebay.co.uk/itm/375128179778 2012 TDV8 Vogue (L322)
Post #695346 1st Jul 2024 11:55am
knwatkins
^^^one of my family members has one of these and is very happy with it. Kev
Post #695348 1st Jul 2024 12:36pm
JayGee
I'll buy it for the next oil change as the one i bought is in the bin. After 3 x 95deg intensive stain wash cycles using loads of detergent I finaly got the oil stains out of my jeans. I've got an MOT on Thurs and I wonder if they will tell me I have a bad oil leak at the front of the engine..... 2012 TDV8 Vogue (L322)
Post #695384 2nd Jul 2024 6:32am
knwatkins
So what actually happened? Was the hose not tight enough on the pump outlet? Kev
Post #695385 2nd Jul 2024 7:10am
JayGee
It was tight but the design is poor so it just flew off under pressure and the heat of the oil softening the hose. 2012 TDV8 Vogue (L322)
Post #695386 2nd Jul 2024 7:38am
caymanblack
Laughing cheap crap ! Rolling with laughter overfinch modified
Post #695389 2nd Jul 2024 9:24am
knwatkins
Sounds like you had a bit of bad luck JayGee. Glad you got the oil out of your jeans. I suppose there could be a number of reasons why your hose popped off. Like you say, perhaps something has materially changed.
I extracted my oil using the cheap little pump today. I change it every 5k miles which is about 4 times a year at the moment and I've been using it for a few years now.
Here's a video from earlier today...
All out within 6 minutes.
Hopefully you'll have better luck with the next one Thumbs Up Kev
Post #695624 5th Jul 2024 9:36pm
JayGee
The flow on that is way faster than I got. The outlet had a ball with a small hole in it to retain the hose under the compression fitting which was obviously resticting flow for a start and the extraction hose in yours looks thicker - does the L405 have a wider oil extraction tube than on the L322? 2012 TDV8 Vogue (L322)
Post #695637 6th Jul 2024 9:02am
knwatkins
I just measured the extraction tube on the L405 and it has an OD of 8mm. What is it on the L322?
I remember that I replaced the hose between the pump and the extraction tube on my pump so it was a nice tight fit on the extraction tube.
I'm not sure about the ball on the outlet. Will have to take a look. Kev
Post #695639 6th Jul 2024 9:39am
JayGee
That sounds the same as on the L322. 2012 TDV8 Vogue (L322)
Post #695691 7th Jul 2024 11:21am
Page 2 of 4 <1234>
